585,949 active members*
4,151 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > DMG DMC103V 840D Z axis work offset is locked how to unlock?
    Oct 2006
    71
    Im trying to set the work offset on this machine. The DMC implementation of the WCS on this control is really different than whats in the Siemens manual and also very different from my DMG DMC manual that came with the machine, almost looks like it for a different machine or control.
    In machine screen, I can go to scratch then press "Z0 base", which I assume is G53 the settable offset. I was able to reset x and y to zero at the work offset but not z.
    Is there some trick not described in regular manuals that you need to do on a DMG DMC siemens machine to set the Z offset? I assume that if I set one tool to the work offset position, they will all be set correctly as they are all referenced to the height of the laser measurement system at their tip.
    Aug 2011
    419
    Re: DMG DMC103V 840D Z axis work offset is locked how to unlock?
    Enter password for higher access level
    "Imagination is more important than knowledge."
    Apr 2022
    Dear all
    I need help .
    Looking for all documentation for DECKEL MAHO DMC103V and DMC 60.
    Many thanks in advance.
    My email: [email protected]
  1. How to setup tools on a DMC103V with 840D control
    By markp in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-30-2019, 06:32 PM
  2. Sinumerik 840D sl locked
    By Ile in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 11-25-2016, 10:21 AM
  3. Siemens 840D controller. Locked in middle of tool change
    By Chuck - Detroit in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-03-2009, 03:31 AM
  4. Siemens 840D on Deckel machining center. Locked in middle of tool change
    By Chuck - Detroit in forum Controller & Computer Solutions
    Last Post: 10-27-2009, 11:47 AM
