585,969 active members*
4,602 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > acramatic 2100 realtime cpu board bios
    Hi guys please
    I have a Cincinati CNC machine ARROW 500, i have a problem with realtime cpu board part number is 3-424-2168A02 and error is NC Engine base failed.
    And i replaced the battery and i need the bios programming file and set up for the bios
    Any help would be greatly appreciated
    Many thanks
    Ihab abass
    Re: acramatic 2100 realtime cpu board bios
    Hi Ihab, glad to see you were using the forum.
    Martin Josse
    Sep 2007
    31
    Hi Have you access to programming bios? I have made a tutorial on this forum for this. If you want some help PM.
    Quote Originally Posted by Ihab_abass View Post
    Hi guys please
    Many thanks
    Ihab abass
    Mar 2008
    285
    Ihab Abass
    Fives-MSI Cincinnati can Re-Flash the BIOS using a Floppy Disk Program; we then Test it in a Simulator with a CMHD I/O Board Tester, DV5 and Pendant.
    Call us 800-934-0475 Cincinnati&Repair Prompts; or Direct at 859-534-4750 ask for repair, or Technical Support.
    Greg
  1. A2100 Realtime board BIOS help request
    By spumco in forum Cincinnati CNC
    Last Post: 04-01-2023, 12:34 AM
  2. Acramatic 2100 Realtime CPU Board BIOS
    By leandro2311 in forum Cincinnati CNC
    Last Post: 03-03-2023, 09:19 PM
  3. Acramatic 2100 Realtime CPU Board BIOS 2a5led42
    By paquiro99 in forum Cincinnati CNC
    Last Post: 03-04-2019, 02:18 AM
  4. acramatic 2100 bios help??
    By jerrybmiller3 in forum Cincinnati CNC
    Last Post: 10-26-2018, 05:26 PM
  5. Acramatic 2100 Realtime CPU Board BIOS
    By turbotadd in forum Cincinnati CNC
    Last Post: 01-28-2017, 04:42 PM
