585,974 active members*
4,318 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle stopped during milling YL-620 2.2kW spindle
Results 1 to 8 of 8
    Dec 2019
    7
    So my spindle stopped during milling last night. It had been running for 2 hour straight.
    Both the spindle and the VFD is new from China.
    I couldnt feel any heat from the spindle, or abnormal smell from either the VFD or the spindle.
    The VFD shows Error 4 which I understand is a normal error on these VFD's
    The error shows when I press Run on the VFD panel. The error will also show if the VFD and the pindle is disconnected and I press run.
    I measure 2.9ohms between all the spindle pins except for ground.
    Anyone have an Idea of what I should do next?
    Is the spindle probably ok?
    Nov 2013
    4372
    Re: Spindle stopped during milling YL-620 2.2kW spindle
    what does the VFD manual say about Error4?
    Craig
    Dec 2019
    7
    Craig
    It says:
    IPM alarm (short circuit)
    Description (from the manual):
    When the motor is running, fault in the internal power component module of the converter occurs:
    1. The accelleration and deceleration is set too short:
    2. The overcurrent and overheating of the converter, please check wheter the motor is shortcircuited, and the machine load is to high;
    3. The input voltage is too high/too low, or the input voltage fluctuates substansially.
    4. The converter does not match the motor power, or fault in Wye-delta.
    5. Improper setting of DC injection brake parameters (P01.09-P01.17):
    6. Improper setting of VF parameters (P00.04-P00.12)
    7.The cooling fan is damaged or in locked rotor, the converter cooling is not good;
    8. Gate driving voltage of components is too high or too low, which need repairing.
    Nov 2013
    4372
    well that just about covers every possible fault God and Man ever created!
    I would guess that the VFD is faulty....but how to prove it.
    Is it covered by warranty?
    Craig
    - - - Updated - - -
    Craig
    Dec 2019
    7
    I also guess its the VFD since its been starting stopping and running perfectly until it suddenly failed in its ~third hour of use.
    I guess there is no warranty, but Ill probably will be able to get some money back via aliexpress.
    If anyone has an idea of what could cause this and a fix it is appreciated.
    15362
    Quote Originally Posted by caap86 View Post
    What voltage are you using for input Voltage to the VFD Drive ????
    These VFD Drives are not very good and would not buy one even though there are a lot of them out there most have some kind of problem with them
    Er04 IPM Fault the drive has failed and needs to be repaired
    Have to look at what has caused it to fail wiring or Parameter settings
    Mactec54
    Dec 2019
    7
    220-221V
    Nov 2013
    4372
    I think you should consider a better quality VFD.
    Hitachi have a pretty good reputation. I've had a lot of success with Delta. Taiwanese brand, manufactured in China. Have been making VFD's, servos/drives
    for years, quality at a fair price......similar price to Hitachi.
    Craig
  1. Spindle just stopped spinning.... cnc
    By potts43 in forum Spindles / VFD
    Last Post: 09-16-2018, 08:54 PM
  2. Vfd spindle just stopped spinning.
    By potts43 in forum Phase Converters
    Last Post: 12-15-2017, 04:43 PM
  3. Spindle does not stopped after M5 call!
    By hatakekakashi in forum Fanuc
    Last Post: 09-27-2011, 06:59 PM
  4. F20 spindle stopped
    By settingbur in forum Want To Buy...Need help!
    Last Post: 05-16-2011, 09:42 PM
  5. Spindle stopped turning
    By WoodMizer in forum Chinese Machines
    Last Post: 05-16-2011, 06:46 AM
