585,973 active members*
4,213 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > CNC milling for rotary engraving
    Jun 2012
    I have to move out of laser engraving for health reasons. Ideally, it is an opportunity to expand into CNC rotary engraving. I don’t know what the state of the art is as far as machines go. Are there CNC mills that can also manage engraving plastic name badges and such? Failing that, does anyone have a handle on the latest advances in rotary engraving set ups?
    Dec 2013
    5717
    Re: CNC milling for rotary engraving
    Quote Originally Posted by djcaswel View Post
    The short answer is yes. The marketing guys have tried to blur the line between CNC routers and CNC milling machines. They are completely different machines, most of the CNC ''milling machines'' you see on EBay are in fact CNC routers.
    Most of the inexpensive table top routers would make a decent engraver. Available from about $400 and up.
    Inexpensive mills typically don't have the spindle speed to run small engraving bits. But a high speed spindle could be adapted in most cases, I have a small 35,000 RPM air spindle for my mill.
    What work area do you need? What is your budget? What are your real needs?
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2019
    What are your production needs?
    Chono
    Nov 2005
    222
    Just curios. Was using the laser engraver causing health issues?
  1. Rotary Engraving Issue
    By George Brown in forum Camaster
    Last Post: 07-20-2011, 03:50 PM
  2. Rotary Engraving Problem
    By coykiesaol in forum FlashCut CNC
    Last Post: 09-19-2010, 05:02 AM
  3. Best Mini Mill for Rotary engraving
    By nosplinters in forum Benchtop Machines
    Last Post: 08-17-2009, 01:46 AM
  4. A-Axis rotary engraving
    By Janos in forum Mastercam
    Last Post: 02-05-2007, 11:20 PM
