585,728 active members*
4,528 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Y Slave axis = A axis judders and doesnt work as good as others
    Dec 2017
    53
    Question Y Slave axis = A axis judders and doesnt work as good as others
    Hi
    Im having some issues
    I was wondering if anyone else has had this issue
    My slave axis = A
    The A Axis after lying ideal doesnt move?
    or judders etc
    my connections and motors are all 100% checked again and again
    im thinking now that the one x Power supply im using to drive the 4 x Nema 23 MOTORS Isnt enough and when the system is ideal, doesnt move the same as before
    Im thinking the the PSU doesnt have enough Amps or voltage to help drive the 2 x axises at the same time?
    I get it working and im all happy then come back 5 mins later and the A axis will not move
    what do you guys think?
    Power supply or dodgy driver board?
    adam
    Jul 2018
    6319
    Re: Y Slave axis = A axis judders and doesnt work as good as others
    Hi Adam - Sounds mechanical. Have you really checked the mechanics are all OK? On my machine this has happened and it turned out the grub screw on the motor shaft was loose. Since then only use strong loctite for all shaft connections. Peter
    Dec 2017
    53
    Hi Peter i actually checked that also
    This is strange but its all good now!
    I checked all the dip switches on the drivers and messed with mach3 settings "motor tuning"
    ive saved all the settings and switched of PC and Controller 3 x times now and its all very good!
    Underneath my A axis BELT! There was a small bit of plastic under the belt so sure that didnt help!
    I have a new issue and question but think its best to do a new post for that!
    THANKS PETER
    Dec 2017
    53
    SPOKE TO SOON!!!!!!!
    Just did it again!
    Im going to try another power supply! to boost the AMPS! anyone else have this issue??????
    Dec 2017
    53
    Just an Update!!!!!!!!!
    WORKING GREAT NOW!
    To anyone else who has this issue of any JUDDERING type effect on your axis!
    In my case it was down to the power supply " I used a new Mean Well power supply and dedicated that to my A Axis! and guess what works 100% now
    So the other power supply was being shared over different drivers and i assume it didnt have enough amps there to get things moving freely!
    thanks
    adam
  1. Will swap axis work properly with an axis that has a slave?
    By QuinnSjoblom in forum Mach Software (ArtSoft software)
    Last Post: 03-15-2019, 09:08 PM
  2. MKX-4 Mach3 don't work slave axis home
    By plUA in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-24-2018, 06:15 PM
  3. Slave axis moved opposite from Master axis
    By jimskeet in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2017, 05:33 AM
  4. Replies: 0
    Last Post: 11-13-2015, 04:37 PM
  5. tk to axis doesnt work
    By Lomach in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2012, 08:58 PM
