585,760 active members*
4,132 visitors online*
    Jan 2007
    626
    Mach 3 tuning
    When I finished making my external Speed and Feed Override inputs to Mach 3, one of the inputs sits at 101% and so is continuously bringing up the 'Overriden' Warning.
    I'm using 'centre detented' pots so not much I can do about that.
    Anybody know if there is a way to desensitize Mach3 so it doesn't see any change until , say 5% either way?
    Some sort of damping?
    Steve
    Nov 2012
    1267
    Re: Mach 3 tuning
    I don't know how to fix it on the software side, but you can add a permanent resistor (or a trimpot) to make the detent position exactly 100%.
    Jan 2007
    626
    Re: Mach 3 tuning
    Quote Originally Posted by CitizenOfDreams View Post
    Thinking about it some more, I think you are right.
    I'll take the device apart and measure the resistances on each side, at the centre position, then add in a trim pot to the low side so i can adjust the centre point.
    Should be all good.
    Will be interesting to see what the difference is. I did not expect to see an error.
    I did reduce the range to +_50% so I guess a 1% error on MAch 3 represents a 2% error in the pot.
    Steve
    Re: Mach 3 tuning
    You can also replace the "overridden" LED with a user LED, and use a macropump macro to control it.
  1. Mach motor tuning
    By skylanehku in forum Machines running Mach Software
    Last Post: 08-17-2012, 06:03 AM
  2. Mach 3 motor tuning
    By corneliusbrown in forum Mach Software (ArtSoft software)
    Last Post: 01-27-2011, 11:15 PM
  3. Mach Tuning
    By 5artist5 in forum Taig Mills / Lathes
    Last Post: 06-16-2009, 05:41 PM
  4. Mach 3 motor tuning
    By nenetwork in forum Mach Software (ArtSoft software)
    Last Post: 03-03-2009, 08:43 PM
  5. tuning steppers in mach
    By dgalaxy in forum Stepper Motors / Drives
    Last Post: 11-20-2006, 03:59 AM
