585,942 active members*
3,687 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > How to wire THC controller (SF-HC25C3) to Sherman Cutter-70.
    Dec 2019
    Recently I bought CNC portable plasma cutter with SF-HC25C3 THC controller ( I attached specification) and I would like to wire it to my plasam cutter which haven't got any plug dedicated to connect THC. There is Arc+ and Arc- output in specification but the question is how and specifically where to connect it?
    specification: https://megawrzuta.pl/download/90380...4f03aae18.html
    Dec 2019
    Thanks for the amazing insight
    Dec 2019
    Aug 2020
    Re: How to wire THC controller (SF-HC25C3) to Sherman Cutter-70.
    Hi Bro,
    I have the same hardware but I don't know how to correct wire the plasma unit with the TCH. can you please give me some guidance.
    Thanks in advance
    Borta
  1. DIY CNC Hot Wire Cutter
    By koko97 in forum CNC Wire Foam Cutter Machines
    Last Post: 11-07-2015, 02:15 PM
  2. New hot wire cnc cutter
    By wantacnc in forum CNC Wire Foam Cutter Machines
    Last Post: 02-05-2015, 03:36 AM
  3. CNC hot wire foam cutter and USB controller
    By Kroko in forum CNC Wire Foam Cutter Machines
    Last Post: 08-23-2010, 07:29 AM
  4. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 10:15 PM
