585,743 active members*
4,858 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need some general advice on VFD parameters for a spindle
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Jul 2008
    29
    Re: Need some general advice on VFD parameters for a spindle
    I did a 13-08=4 factory reset. Then I input all of the codes again.
    00-06 the Alt Freq command source - defaults to 4 ( external ) and would not accept 1 ( Pot on keyboard )
    01-04 Middle Output Freq would not accept 0. I tried a number of other values and it finally accepted 200.
    01-05 Middle Freq voltage ratio 2 would not accept 0. It automatically input 115 which I accepted.
    The motor ran much as before and responds normally to the pot but as I bring the frequency gets down to about 157 Hz, the motor slows to a complete stop.
    And then I went back to try to sort out the values that would not be accepted and now nothing works. I get an OC-A error : Output current exceeds the over current level.
    I seems that with certain inputs being made, the VFD does a bit of its own math and changes other parameters. Probably some that are not on my list but ones that are being reset by the 13-08=4 factory reset. I'm going to go back and do it all over again.
  2. #22
    15362
    Quote Originally Posted by David Morrow View Post
    It sounds like the VFD Drive is not suited for your spindle, but also may be something simple
    After you do a reset just put in all the motor spec's and what the Keypad needs the Minimum and Max Frequency 133.4 and 400 and then try it again
    You get that fault because the motor is not running correct and will damage it if it keeps doing this
    Mactec54
  3. #23
    Jul 2008
    29
    The spindle wiring is fairly straight forward - 4 pins but only 1,2, and 3 are used. Is there a way to test the motor pins to be sure that the right ones are being used and connected correctly ?
  4. #24
    Jul 2008
    29
    It seems that 01-08 and 01-09 seem to be the issue. When I go into those parameters after setting everything else, the VFD has entered values of .60 and 2.2 respectively. I find that if I just leave those values, the motor runs. I'm going to leave it there for now and maybe get a tachometer to measure the spindle speeds.
    Thank you so much for your help and patience. I will report back in as things develop.
    The next thing is to connect the external controls. I left that out of this step as that would mean way to many variables to sort through.
    https://www.factorymation.com/30PBA3-N12-300-AS_2
  5. #25
    15362
    You can not use a normal meter to measure the output Power of the VFD Drive
    You have to use all 4 Pins the spindle must be Grounded this sounds like another problem you have
    The normal connection is
    Pin 1=U
    Pin 2=V
    Pin 3=W
    Pin 4=Ground which in most spindles is not connected this needs to be connected your air cooled spindle is a little harder to connect from the plug to the spindle Body
    Remove the plastic cap and connect a Ground wire to Pin 4 and then cut out part of the cap where the mounting screws hold it on you will use a stud and lock nut to mount the Ground wire crimped on fitting and then a nut to hold the plastic cover back on
    You can not use the Spindle without a Ground wire from the spindle to the VFD Drive this cable needs to be 4 wire Shielded and Grounded correctly
    Mactec54
  6. #26
    15362
    Yes that is the correct way to get a drive like this going to use the KeyPad first and then go remote, you don't need that type of switch button control you can do it all through your control software
    I have another Parameter list to try, although what you just posted this may not change much but I did leave out some of the parameters you where having trouble with and have added some others
    The 60 is relating to a 60Hz motor which could be a problem and may mean that the drive is not suitable for your spindle or could be still just a Parameter conflict
    00-00=0 V/F Mode
    00-07=1
    00-08=400
    00-11=400 ????
    00-12=400
    00-13=133.4
    01-02=220
    01-02=400
    01-08=133.4 ????
    02-00=80%
    02-01=3
    02-03=24000
    02-04=220
    02-05=.8
    02-06=400
    00-00=2 Vector mode only change this if you are going to try Vector mode IF you do you can then use Auto Tune
    These motor spec's should be set
    17-01=.8
    17-02=3
    17-03=220
    17-04=400
    17-05=24000
    Mactec54
  7. #27
    Jul 2008
    29
    I am happy to report that I have now wired the external Start / Stop / Variable Speed Control potentiometer and have the related VFD parameters set. That means not having to use those tiny Start, Stop, and speed controls on the face of the VFD.
    External control box : https://www.factorymation.com/30PBA3-N12-300-AS_2
    I will leave the Google Sheet with the VFD parameters in place for reference for anyone else who may face the same hurdles that I did.
    https://docs.google.com/spreadsheets/d/1W4X_DvuCc1bX9P3939E15rDRaK6fd7wsmvdbrKgH90g/edit#gid=0
  8. #28
    15362
    Good to hear you are running if you had just moved my list up ( 2 ) spaces up to 01.04 and left the bottom 2 at the default you would of had the same outcome
    What got me was the Middle output frequency 2 normally when you see a ( 2 ) that means for a second motor control in other drives
    Mactec54
Page 2 of 2 12
  1. General EDM tap removal advice?
    By Jessop in forum EDM Discussion General Topics
    Last Post: 11-21-2018, 02:35 PM
  2. General advice on height of components
    By No1Daemon in forum DIY CNC Router Table Machines
    Last Post: 08-11-2011, 04:44 AM
  3. any general advice for a beginner?
    By ben1mac2 in forum MetalWork Discussion
    Last Post: 08-10-2011, 12:52 AM
  4. General advice and equipment advice
    By GeorgiaRaised85 in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2010, 11:00 AM
