585,719 active members*
4,194 visitors online*
IndustryArena Forum > Community Club House > Computer Technology > USB, RS232, PARALLEL etc > Wiring manual pulse generator directly to 2nd parallel port
    Nov 2007
    361
    Hello to all I am trying to add a manual pulse generator to my cnc router via parallel port. I installed a 2nd pci parallel port card to my pc and I have the pinout for the mpg. I just dont know how to get the 5v and 0v from the pc to the mpg here is the pinout and mpg I have
    Attached Thumbnails Attached Thumbnails Screenshot_20191210-143408_Chrome.jpg
    Aug 2009
    230
    Re: Wiring manual pulse generator directly to 2nd parallel port
    The disk drive power connectors in the PC will have +5v, +12v, and ground connections on it. You can get a drive power extension cable, clip off the side you don't need, and use that to gain access to the power lines you need.
    Nov 2007
    361
    Quote Originally Posted by __Britt View Post
    Britt, thanks for the reply and ...wow I didnt even think to use the PC's board to get my power from.
    Nov 2007
    361
    Hey britt can you post some pictures of the cable you are referring to so I will know which one to splice into
    Mar 2007
    2083
    you can connect to the red and black wires from a 4 pin MOLEX or 15 way SATA power cable
Name:	MPG   pulse generator + 4 pin molex.jpg
    or
    a USB cable
Name:	USB pinout.jpg
    John
  1. connect motor driver directly to the parallel port
    By Mach3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-23-2012, 08:25 PM
  2. Need help with manual pulse generator
    By Jackal66 in forum CNC Machine Related Electronics
    Last Post: 10-26-2011, 05:52 PM
  3. Manual Pulse Generator for K2CNC
    By Mike Stevenson in forum K2CNC
    Last Post: 09-03-2009, 09:23 PM
  4. Manual Pulse Generator
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 06-13-2008, 02:31 AM
  5. Manual Pulse generator?
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 07-24-2006, 04:10 AM
