585,712 active members*
3,929 visitors online*
Results 1 to 7 of 7
    Oct 2014
    27
    Parallel lines
    Please could you help me. I’ve to put in parallel two line of engines. Examplíe: x with z and y with a. Which is the command that I’ve to applaid?
    Thanks a lot. Dalmazio.
    May 2006
    4045
    Re: Parallel lines
    Hi Dalmazio,
    I don't understand what you are asking. Possibly Master/Slave configuration?
    TK
    http://dynomotion.com
    Oct 2014
    27
    Re: Parallel lines
    [QUOTE = TomKerekes; 2341958] Ciao Dalmazio,
    non capisco cosa stai chiedendo. Possibile configurazione Master / Slave ? [/ QUOTE]
    dear tom, yes, x master z slave, y master a slave thank
    Oct 2014
    27
    Re: Parallel lines
    May 2006
    4045
    Re: Parallel lines
    Hi Dalmazio,
    I'm not sure whether you still have a question.
    It would be better to reference KFLOP Axis Channels. ie.
    X = Master KFLOP Axis #0, Slave KFLOP Axis #2
    Y = Master KFLOP Axis #1, Slave KFLOP Axis #3
    TK
    Oct 2014
    27
    Re: Parallel lines
    thanks tom, should I write these commands in the consol?
    May 2006
    4045
    Re: Parallel lines
    Hi Dalmazio,
    No you should configure the KFLOP Axes appropriately in the configuration screen as described in the Link I provided. Configure the each Slave axes to follow the appropriate Master.
    Then configure the XY Coordinate System with:
    DefineCoordSystem(0,1,-1,-1); // define X as Axis #0 and Y as Axis #1
    TK
  1. no new computers have parallel?? experience on adding parallel port yourself?
    By teglberg in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2014, 07:18 PM
  2. Replies: 9
    Last Post: 01-11-2014, 11:04 PM
  3. Replies: 2
    Last Post: 08-26-2013, 07:37 AM
  4. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
  5. parallel lines
    By daisydog in forum Rhino 3D
    Last Post: 02-09-2008, 05:34 AM
