585,715 active members*
3,819 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Wire Flattener - Otto2 Wire Flattener
Results 1 to 2 of 2
    Aug 2011
    303
    The Otto2 Wire Flattener is capable of 2 way flattening of both aluminum & copper, film coated magnet wire. Flattener is designed to work with coil winding machinery. These are new, unused machines.
    https://www.ebay.com/itm/Wire-Flatte...oAAOSwH8Vd8Tr3
    Features:
    -2-way flattening of CU and AL up to 8 AWG. 6 AWG possible with larger motor and drive.
    -Single flattening head on single machine base.
    -Maximum flattening speed of 1500 ft/min.
    -Fixed rolls. No grooved rolls to purchase or change.
    -Wire thickness continuously adjustable in 0.5 mil steps from .005” to .375”.
    -6" diameter flattener rolls with digital roll gap indicator
    -Standard 10 HP motor and drive
    -Wire-out switch for customer connection to winding machine.
    -Flattener speed exceeded relay for connection to winding machine.
    -Customer connection for drive enable/disable. Typically used for low air pressure.
    -Adjustable dancer pressure.
    -Dual jog switches for manually feeding wire.
    -Quick flattener head disassembly for easy maintenance.
    -Dimension: 24" x 70" x 72"h
    Machine(s) can ship via freight at buyers expense within the United States only or pick up in Athens, GA
    Aug 2011
    303
    Re: Wire Flattener - Otto2 Wire Flattener
    If you are interested or have specific questions, please email us at [email protected]
  1. Replies: 0
    Last Post: 02-08-2017, 02:24 PM
  2. USER MANUAL SODICK MARK X or XI wire EDM, and wire breakage
    By stan34 in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2015, 03:56 PM
  3. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum EDM Discussion General Topics
    Last Post: 01-25-2011, 01:49 PM
  4. want to build decoiler & sheet flattener
    By Bill Chung in forum Want To Buy...Need help!
    Last Post: 12-01-2010, 05:47 AM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
