Hi Folks,
I purchased an ‘89 Fadal 4020HT that had been out of use for about two years. The ways appear pretty good but the controls need to be updated/repaired and the inverter also repaired. I’ve been cleaning the coolant tank and ordering some parts that were determined to be faulty (Crydom solid state relays). I’ve even made a toe jack in order to get the new feet on and level the machine. I’ll be wiring the machine (3-phase -15HP) this weekend. The interior of the machine both inside the electronics/power cabinets and inside the machining cabinet is filthy. I’ll wait to clean the machining area until I can move the saddle and clean underneath it. The company I work for “donated” about 4 gallons of coolant concentrate (Val-cool Turn Tech) so when the machining cabinet is freshly cleaned I’ll be loading in the coolant and spraying everything down to prevent rust.
If anyone has any words of wisdom I’d be glad to hear them. I’m going to have plenty of questions when it comes time to update the controls
