Originally Posted by
ubergeekseven
I use the Bosch 1617. I really want a true spindle though. You have to run it full bore to get the true HP it claims. So you have to play around on feeds and speeds to get what you want out if it.
I'm definitely getting a spindle, but probably going Chinese. You can get, essentially, the same or better results for$600. But you have to set up the vfd and that's not something I have done previously. I know it will not be that hard, but the time invested in getting it up and running correctly is enough to procrastinate.
I have a 4x8 pro.
