584,874 active members*
5,135 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Rhinocam mach3 query
Results 1 to 6 of 6
    Feb 2013
    81
    Hi
    I am used to generating gcode from Vetric software but though i’d try out Rhinocam. I ran the same pocketing toolpath in both software to compare. I’m used to the the tool retracting to safe Z and then returning to zero’d position but remaining at the safe z. Rhinocam retracted to safe z didn’t move to zero’d position. I wonder what instruction to add to the Rhinocam Mach 3 post processor to give it the instruction to move to job zero position, see gcode.
    Any thoughts on this would be most useful.
    Aspire
    (Toolpaths used in this file
    (aspire 150x75 Roughing)
    (Tools used in this file: )
    (1 = End Mill {6 mm} roughing wood)
    N100G00G21G17G90G40G49G80
    N110G71G91.1
    N120T1M06
    N130 (End Mill {6 mm} roughing wood)
    N140G00G43Z20.000H1
    N150S12000M03
    N160(Toolpath:- aspire 150x75 Roughing)
    N170()
    N180G94
    N190X0.000Y0.000F3600.0
    N200G00X86.445Y-162.500Z5.000
    N210G1Z0.020F1200.0
    N220G1Y-12.500F3600.0……………….
    Middle gcode removed
    N800G1Y-162.500
    N810G1X14.445
    N820G1Y-12.500
    N830G00Z5.000
    N840G00Z20.000
    N850G00X0.000Y0.000
    N860M09
    N870M30
    Rhinocam
    G00 G49 G40.1 G17 G80 G50 G90
    G21
    (Horizontal Roughing)
    M6 T3
    M03 S12500
    G00 Z6.0000
    X87.5000 Y-162.5000
    G01 Z-1.7650 F4000.0
    Z-2.4000 F1500.0
    Y-12.5000 F3600.0
    X85.1000
    Y-162.5000
    X82.7000
    Y-12.5000
    X80.3000
    Y-162.5000
    X77.9000
    Y-12.5000
    X75.5000……………….
    Y-162.5000
    X12.5000
    Y-12.5000
    Z-1.7650 F3000.0
    G00 Z6.0000
    M5 M9
    M30
    Oct 2005
    169
    Re: Rhinocam mach3 query
    If you just want to rapid to your Zero position, this is happening in your first program here:
    N850G00X0.000Y0.000
    You can alter your post in RhinoCam to add this in the end of the program, or the end of each tool.
    Feb 2013
    81
    The Mach3 post in Rhino is giving me these option on start/stop.
    Excuse my ignorance* but is it all or part of 'N850G00X0.000Y0.000' to add to the end?
    *I really should have learnt more about G commands before launching into the world of cnc.
    [START_CHAR]
    [SEQ_PRECHAR][SEQNUM][DELIMITER]G00 G49 G40.1 G17 G80 G50 [OUTPUT_MODE_CODE]
    [SEQ_PRECHAR][SEQNUM][DELIMITER][OUTPUT_UNITS_CODE]
    [SEQ_PRECHAR][SEQNUM][DELIMITER]M5[DELIMITER]M9
    [SEQ_PRECHAR][SEQNUM][DELIMITER]M30
    [STOP_CHAR]
    Oct 2005
    169
    [SEQ_PRECHAR] puts the N in the line.
    [SEQNUM] puts the actual line number after the N.
    [DELIMITER] adds a space in this instance, but can be changed to other characters if needed. (The space appears to be fine at the moment)
    Try the following:
    Code:
    [SEQ_PRECHAR][SEQNUM][DELIMITER]G00[DELIMITER]X0.0000[DELIMITER]Y0.0000
    [STOP_CHAR]
    Moving to your zero position may be what you want here, but more commonly machines are sent to the "Home" position at the end of a program which is often performed by a "G28" line. Do what works for you though.
    Feb 2013
    81
    Thanks a lot!
    Yes correct, I want to move to my zero position. I'm just off to the workshop now so i'll try this out.
    Feb 2013
    81
    Quote Originally Posted by beezerlm View Post
    Try the following:
    Code:
    [STOP_CHAR]
    Tried it and it worked a treat, thanks!
  1. Rhinocam 2016 to mach3 mm loosing steps V carving embossing
    By oxcncmill in forum Machines running Mach Software
    Last Post: 04-17-2018, 08:18 PM
  2. DNC Query
    By slowtwitch in forum Fadal
    Last Post: 07-21-2017, 02:24 PM
  3. Weird circle G03 in Rhinocam Mach3 inch post
    By btsioles in forum Rhinocam
    Last Post: 10-22-2014, 09:56 PM
  4. rhinocam post processor for mach3 for 5axis
    By komar197021 in forum Rhinocam
    Last Post: 07-28-2012, 10:29 PM
  5. Replies: 17
    Last Post: 06-01-2011, 12:48 PM
