512,259 active members
4,037 visitors online
    Low Cost - CNC Router design
    I am looking at cnc routers for wood. Some have 2 motors to move the gantry some have one. How do I choose between 1 and 2. Is it better balanced or does it produce more force or both.
    I am an inexperienced cnc router user. I will be making signs.
    Tom
    Member
    Jul 2018
    1017
    Re: Low Cost - CNC Router design
    Hi Tom - The long axis with a gantry can be driven on small machines with one drive (screw or belt) under the table via a saddle. On large machines its usual to drive the long axis with two motors, one either side. If the design is functioning then one or two is fine. If you have seen a machine in which only one side of the long axis is driven this is most likely for a machine like a plotter or laser that does not have any contact force at the "tool". These would not work for routing work. Peter
    Gold Member
    Apr 2004
    4909
    It's to combat the "stuck drawer" problem: what happens when you try to open a wide bureau drawer by pulling on only one of two handles. It works a lot better if you pull on both handles at once. That's what you get when you "slave" the two X-axis motors together, so they pull at the same rate on either side. You'll need to provide an extra driver, but unless your machine is particularly narrow, it's worth doing.
    Andrew Werby
    Website
  1. Replies: 0
    Last Post: 05-21-2019, 04:40 PM
  2. NEW DESIGN CRASH RESISTANT LOW COST TOUCH PROBE
    By keen in forum Tormach Personal CNC Mill
    Last Post: 05-06-2018, 12:17 AM
  3. Cnc router factory cost
    By omnisales6 in forum European Club House
    Last Post: 07-26-2016, 03:56 AM
  4. low cost CNC router design questions
    By bigg in forum DIY CNC Router Table Machines
    Last Post: 07-02-2007, 07:52 PM
  5. Extremely low-cost first router
    By ScuD in forum CNC Wood Router Project Log
    Last Post: 12-22-2005, 01:10 PM
