585,987 active members*
4,500 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > New to me Tree Journeyman 425
Page 2 of 4 1234
Results 21 to 40 of 67
  1. #21
    Nov 2013
    152
    Re: New to me Tree Journeyman 425
    Removed the Dynapath Delta 20 Control and servo drivers. Hoping I can get a few bucks for it all to help pay for the new stuff. The cabinets were like the rest of the machine. Absolutely filthy. A little better now.
    I could put the new control in one cabinet, but I think I’ll stick with the existing layout with the incoming AC supply and spindle drive in a separate enclosure. It’s already laid out that way.
  2. #22
    Dec 2013
    5717
    That's the way I would do it, power handling on one side and controls on the other. Really helps with the noise issues keeping the power and controls separated. Looks like the cabinets cleaned up nicely.
    Jim Dawson
    Sandy, Oregon, USA
  3. #23
    Nov 2013
    152
    Worked on the X and Y axis servos. Removed the 500 pulse encoders and tachometers. Mounting the new encoders looks straightforward. Half inch shafts in the two different servos.
    I’m thinking I’ll make a new end cover.
  4. #24
    You should be able to get rid of one of those cabinets. You could probably use the surplus one as emergency accommodation! With sensible (normal) wiring precautions including a proper EMC filter, you shouldn't have an issue with VFD noise. If you have to use two cabinets to avoid noise issues, your wiring needs another visit.
    Unless you plan to use this machine for hacking the top off large castings, it's hard to see how you could make use of much more than a few kW of spindle power on a continuous basis. Seems the motor is rated at 3.7kW continuous and 5.5kW peak which is about 5hp and 7hp respectively - so something like a Yaskawa 3.3kW drive (which is also specified with a similar short term peak rating, not surprisingly) would be fine. Even a non-industrial drive like a HY 5kW would probably suffice for most hobby work. The good news is that the spindle motor is a proper variable speed jobby, so should be happy to run at high speed all day.
    If you enter the motor nameplate parameters into the VFD, it should protect / prevent overloading the motor, without having to second guess and fiddle the values. Looks to me as if the HY inverters use sensorless vector control, which is pretty much the norm these days, would be surprised to see otherwise. Typically they boast of 150% torque at stall which is a bit of a giveaway.
    Looks like a fine machine despite its age, rather like my Shizuoka AN-S. Mine was a very similar size and spec to this but for most of its life almost certainly never came close to the sort of performance it provides nowadays when run with the modern HSM toolpaths you get with the likes of Fusion 360 / HSM Works. These paths allow a much smoother and more continuous spindle power profile with a higher MRR and less risk of overload. 3kW or so of spindle power will give a pretty impressive stream of chips that may challenge your ability to keep the cutter (and the vicinity) clear.
  5. #25
    Nov 2013
    152
    Drive is the GT series 10HP/7.5kW. The braking seems to be working well.
    In V/Hz mode P0.00 = 0, the drive takes the motor up to full speed of 267Hz. When I change to sensorless vector mode P0.00 = 1, do autotune again, the drive only takes the motor to around 80Hz on subsequent starts. No matter what I do. Same if I go to torque vector mode P0.00 = 2, run autotune again, drive only goes to around 12Hz on subsequent starts.
    I disconnected motor from spindle, thinking that had something to do with the autotune not working.
    P2.00 = 0 (G)
    Decoupling has no effect. In SV mode output current doesn’t go above 3a (about half of speed no load current) and frequency ramp is extremely slow. It’s not limiting output current.
    I noticed autotune doesn’t change anything in P3 (SV) or P4 (V/Hz) settings groups. The manual says the RUN/TUNE LED will flash during autotune. It’s on solid during TUN-1. It does display -END- when complete as motor stops at decel rate. No parameters change.
    For whatever reason autotune does not change anything in group 3 (sensorless vector) or group 4 (V/Hz). It’s not hitting any current limits.
    Emailing back and forth with HY tech support.
    Muzzer- we are on the same page. One of the reasons I’m leaning toward keeping both cabinets is the existing wiring is already laid out for it. Removing it doesn’t gain me anything I care about. Thanks for the info. I appreciate it!
  6. #26
    Apr 2008
    61
    Slodat, what made you change from the 15 hp Fuji drive to the 10 hp HY drive?
  7. #27
    Nov 2013
    152
    Quote Originally Posted by fusion_crank View Post
    There's a lengthy thread about a suitable vfd for the spindle motor.
    The short version is, the HY drive is a temporary way to get the spindle turning for relatively low money. I plan to use it for a while and see how it goes. If it isn't up to the task, I will replace it with a better drive. The Fuji is not an option after all because the 4 pole spindle motor is at 8000 rpm at 267Hz. The Fuji doesn't work in sensorless vector mode to that high of frequency. So, I'm thinking the drive I will go with will be the Hitachi WJ200-150LF. Partially based on the recommendation of a member on here using that drive on the same mill/motor.
    I've also decided to go with DMM 1.3kW NEMA42 AC servos and DYN4 servo drives with Centroid Acorn instead of Allin1DC.
  8. #28
    Apr 2008
    61
    Thank you slodat. That's great information. I have a Haas Mini mill that had all the electronics removed before I bought it and this information may help me use the stock spindle motor. I had been considering changing out the 7.5 hp motor for a 2 hp motor since they are cheap and plentiful, and this is just going to be a hobby machine. I had thought I was looking at about $1500 for a single to 3 phase FVD with the power to handle a 7.5 hp motor. That's just too much for me.
    Please keep posting your progress. It gives me hope for my project.
    Mike
  9. #29
    Nov 2013
    152
    The Fuji drive won’t run the needed 267hz (full motor speed) in sensorless vector mode. But, the Hitachi WJ-200 will.
    I've deliberated on whether to go with Allin1DC and existing DC servos or DMM AC servos and Acorn. Ultimately I decided to buy the DMM AC servos. There are a few factors in this decision.
    • First was the extreme cost difference for the software unlocks for the servo controls (AllIn1DC is a servo control) vs. Acorn. I have read and been told by Centroid they intend to update this with their next software release, "sometime soon".
    • I am quite familiar with Acorn and I feel like I will be better served having the same control on both. At least for now. I can replace Acorn with Oak should I decide I need closed loop control. I already have an Acorn board on hand.
    • In the case of a component failure, I’m only buying one component, not an entire controller. AllIn1DC has the servo drives built into the board.
    • Cost. This system has a significantly lower cost.
  10. #30
    Nov 2013
    152
    Most of the parts have arrived. Was able to get the control, servo drives and servos bench tested. All went well. Next step is blow this apart and start the build out. Since I know people love photos..
    (It’s bench testing. Not final work. I used chunks of wire I keep in a box for stuff like this. I know it’s a rats nest
    Had a bit of drama with one of the motor pulleys. Found a used one at ZPS. They have been awesome for info and parts.
  11. #31
    Nov 2013
    152
    Had some time to begin panel layout. I’m going to keep both cabinets. I know I could eliminate one. I really like the way it’s setup with the VFD and input power in one and control in the other. There’s tons of room, existing venting for the VFD heat sink, etc.
    What I’ve got thus far..
  12. #32
    Nov 2013
    152
    AC power portion is wired and installed. The machine has two control cabinets. Decided to keep them both and the AC side separate from the electronics. Reusing what I can, but not much original electrical equipment remains.
  13. #33
    Apr 2008
    61
    Wow! That's nice work. And such a nice shop.
  14. #34
    Nov 2013
    152
    Made some progress on the controls panel.
  15. #35
    Nov 2013
    152
    Cut the slot for the cable pass through.
    Starting to look like something.
  16. #36
    Dec 2013
    5717
    Nice Work :cheers:
    Jim Dawson
    Sandy, Oregon, USA
  17. #37
    Nov 2013
    152
    Nice Work :cheers:
    Thank you!
    Started on the control panel today. Used a chunk of 1/4 aluminum I got from the scrap yard. Was some sort of sign. I’ll give the surface a once over with the burnisher next time I have it apart. It’s turning out how I had it pictured.
    I need to weld the lcd bracket standoffs to the front plate, engrave the lettering and sort out the mounting holes.
  18. #38
    Nov 2013
    152
    Powered up the control for the first time today. Control panel is in and working. Lots left. Nice to see the screen up and running.
    The Intel NUC front panel is accessible from the side away from the spindle.The opening was existing. I’ll make a new cover that trims out the NUC front panel.
  19. #39
    Nov 2013
    152
    Short video showing 200ipm rapids from far limits back to home.
    https://youtu.be/QGiPrjAGaH8
  20. #40
    Dec 2013
    5717
    Nice :cheers:
    Jim Dawson
    Sandy, Oregon, USA
Page 2 of 4 1234
  1. Tree Journeyman 220
    By wkbates in forum Knee Vertical Mills
    Last Post: 07-22-2014, 12:13 PM
  2. help tree journeyman 325
    By cnc beginner in forum Tree
    Last Post: 03-05-2014, 07:13 AM
  3. tree 325 journeyman
    By cncrouter in forum Tree
    Last Post: 01-22-2013, 02:45 PM
  4. Tree Journeyman 250 or 325
    By MechWerks in forum Tree
    Last Post: 04-01-2008, 05:26 PM
  5. Tree Journeyman 310 and VFD
    By Provectus in forum Tree
    Last Post: 01-27-2007, 04:13 AM
