585,977 active members*
4,670 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > basic help for newbie cnc milling - z axis needs double
    Hi, I am totaly new. Just trying first pieces create in my Milling CNC 3020t 4 Axis USB CNC Router.
    I am using software: CNC USB Controller. It looks OK but I have some question.
    1. axis x and y is same like in Gcode, in mm. and result is OK.
    But axis Z I need to twice in ccode. For example if I am working with 5mm plexi glass (acrylic)
    I was trying to set Z for -6 ... little bit more than 5mm height.
    But I have to set it to value 12 and it means that I will have 6mm in reality.
    Why?
    Jul 2018
    6337
    Re: basic help for newbie cnc milling - z axis needs double
    Hi - In the config area of the CAM you will need to change the steps per unit value of the Z axis so it movement corresponds to the correct distance. Apparently this value needs to be halved....Peter
    Yes perfect, thanks
  1. NewBie to 4th axis milling
    By willheg in forum FeatureCAM CAD/CAM
    Last Post: 11-30-2011, 03:30 PM
  2. Newbie needs basic help
    By PowermetalX in forum Want To Buy...Need help!
    Last Post: 11-07-2011, 10:53 PM
  3. Newbie basic questions
    By gnr in forum Benchtop Machines
    Last Post: 01-11-2009, 09:54 PM
  4. Lot of Basic Questions from a Newbie
    By mvadu in forum Benchtop Machines
    Last Post: 06-18-2007, 02:53 PM
  5. Basic CAD program for total newbie?
    By hhsmiley in forum Uncategorised CAM Discussion
    Last Post: 05-11-2007, 12:43 PM
