585,582 active members*
4,738 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Plunge rough down to one pass?
    May 2019
    27
    Angry Plunge rough down to one pass?
    Is there anyway to get this down to one pass? The cutter is 1" and even when I shrink the flat width to .3" I get two columns. I just want one path right down the middle. I don't feel this should be that complicated but I can't figure it out.
    I have tried several different combination of contain and avoid area. I am using a face feature since a boss feature doesn't have a plunge rough option.
    May 2019
    27
    Does any one know how to do this?
    Jan 2014
    32
    Re: Plunge rough down to one pass?
    Can you post a screen shot of what your trying to do
    May 2019
    27
    I am trying to remove this boss with plunge rough, with one pass down the middle. I can only get it to where is goes down one edge and back up the other, two passes.
    Quote Originally Posted by sundewzer View Post
    Are you using "Automatic" or "User Defined" under the "Facing" tab?
    If you change it to "User Defined" you can manually define it as a single pass and it should put that pass straight thru the center of the boss. See the attached pic.
