Hi guys... I'm having this issue in camworks when i try to do, for example a closed 8mm pocket with a 6mm end mill after i do the simulation and select "show difference" it turns out it is not a circle it always turns out some odd hexagon like shape. i try all kind of stuffs but im out of ideas i try adding finish pass, rough mill, contour mill, spiral in, out, side allowance zero idk...every time i get the similar result. This is only on the sides !!! bottom cuts are all fine, any help? :/
