586,011 active members*
4,388 visitors online*
Results 1 to 8 of 8
    Oct 2009
    114
    Easy Modelling
    Hi, Is there Easy modelling manual
    thanks
    Jun 2015
    4154
    Re: Easy Modelling
    hi, i guess not ... if you wish, talk with your okuma rep ( or whoever else ), so to remotely set 2-3 different tools, fixtures, etc, and screen-record the session
    when using a normal spindle, parts for such big machines are generally too simple to require easy modelling, considering that there is an experienced operator
    when using the pivot spindle, in most cases, is good to cam simulate / kindly
    Feb 2009
    13
    Re: Easy Modelling
    If memory serves correctly easy modeling directions are part of the operation manual. What model of control do you have?
    Jun 2015
    4154
    Re: Easy Modelling
    hy bbgun, you are correct i was searching for 'modelling' instead of 'modeling'
    just like you said, main explanations are inside the operation manual, but also there are references inside other manuals
    mcr-b2, do you have the manuals in pdf format on your machine ? if you wish, i may sent you infos from my manuals / kindly
    Feb 2009
    13
    I have the manuals. Glad you were able to find it.
    Oct 2009
    114
    Re: Easy Modelling
    Hi friends With your information I found i? in Operation Manual. Correction: Easy modeling not Easy Modelling::cheers:
    Merry Christmas and happy new year
    Jun 2015
    4154
    Re: Easy Modelling
    modeling vs modelling : same word , same meaning. The variation in the spellings arose while searching for a distinctive language that would differentiate usa from british.
    but why should one search for a new language ? is much easier to create one : M3 M003 M=MMM M = SQRT [ VC [ 0010 ] ] + 2
    kindly
    Oct 2009
    114
    Re: Easy Modelling
    You are right
    kindly :
  1. Need Solid Modelling Help
    By AUTOCAD712 in forum GibbsCAM
    Last Post: 04-20-2017, 08:34 PM
  2. Modelling A Pushchair
    By Raz11 in forum Solidworks
    Last Post: 01-23-2012, 06:41 PM
  3. Modelling & linetypes
    By CNC-Hammer in forum Autodesk
    Last Post: 03-31-2009, 08:17 AM
  4. PRS modelling
    By betterfly in forum Musical Instrument Design and Construction
    Last Post: 08-13-2008, 10:00 PM
