585,922 active members*
3,592 visitors online*
IndustryArena Forum > Other Machines > Commercial Products / Manufacturers Support Forums > CNC4PC > C11, ESS and (or) Mach3 issue, no axis movement
    Feb 2014
    197
    If anyone could give me some places to look. I have no axis movement. Controller did work at one time, but computer was upgraded and now this. I have not messed with it for some time now so am very green.
    -Mach3 and ESS are communicating
    -5V exists between the EN and 5V on the C11
    -1V on ports 2,3,4,5,6,7
    -5V on ports COM*
    -Stepper drivers are powered and look good to go
    -Ports are enabled in Mach3
    -No port lights on diagnostic screen
    -I have no stepper movement and no status LED's are lit
    -My C11 is rev 9.8
    Feb 2014
    197
    Re: C11, ESS and (or) Mach3 issue, no axis movement
    You can reach out to us on our ticket system and we will give you a hand with this:
    https://www.cnc4pc.com/contact/
    Arturo Duncan
    https://cnc4pc.com
    Feb 2014
    197
    Here are some of the settings pages in Mach3. I've created a trouble ticket.....but you and I were already emailing.
    If anyone can give me some points to check, it would be appreciated.
    Attachment 433462Attachment 433464Attachment 433466
  1. 4th axis movement with jerks in Mach3
    By Actor28 in forum Mach Software (ArtSoft software)
    Last Post: 06-22-2019, 11:44 AM
  2. Replies: 9
    Last Post: 01-02-2019, 02:43 AM
  3. Fadal 3016 Z-axis movement issue
    By krashen in forum Fadal
    Last Post: 08-07-2017, 09:34 PM
  4. Mach3 Help with axis movement
    By CEStanley in forum Mach Software (ArtSoft software)
    Last Post: 10-13-2012, 04:32 AM
  5. Sheetcam + Scribe + Mach3 - Z Axis Movement
    By unixadm in forum Mach Software (ArtSoft software)
    Last Post: 07-01-2011, 11:16 PM
