585,735 active members*
5,032 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > EdingCNC > More efficient way to mill pockets...
    Jul 2009
    4
    While I was at it with my other post about the CPU2 and lasers, I thought I'd post another question I have.
    I have found that when I mill multiple pockets, USBCNC takes the most inefficient path, at least that's how it looks to my layman eyes.
    ie. I want the pockets to be 9mm deep, with a step-size of 3mm because of the small endmill I have to use because of the tight radius-es of the corners.
    USBCNC creates the G-code in such a way that it first moves from pocket to pocket and mills each only 3mm deep, then it does the same for 6mm and 9mm and eventually also for the finish allowance.
    All this moving from one pocket to the next takes a lot of time if there are a lot of pockets to mill.
    Is there a way to make USBCNC write the G-code so each pocket is completely finished before it moves to the next pocket?
    Thanks.
    Re: More efficient way to mill pockets...
    Are you "Still" using the EdingCNCProgam Tab?.. There is better CAM software available.
    I have been Using EdingCNC for 15 years now, and i have only used the program Tab from EdingCNC once..
    For CAM i've been using CAMBAM for16years now.. i used that before i converted my Mill to EdingCNC (then still called USBCNC)
    Bert Eding once explained to me that he wanted the program tab become an embedded CAM system, but the software he bought to get that working was giving him a headache, so he stopped the devellopment of that, therefor it is what it is now, and will not get any updates, and is most likely to disappear in future versions..
  1. Replies: 0
    Last Post: 04-01-2016, 07:55 PM
  2. Most efficient way to part on a mill
    By FuriousGeorge in forum Tormach Personal CNC Mill
    Last Post: 04-30-2015, 10:29 PM
  3. How to choose most efficient End Mill Size for the job?
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 06-07-2014, 03:23 AM
  4. Knee mill conversion cant make circular pockets
    By CLSmachining in forum DNC Problems and Solutions
    Last Post: 10-05-2012, 02:46 AM
  5. Friction Co-efficient of Air
    By Al_The_Man in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-05-2006, 06:22 PM
