585,974 active members*
4,304 visitors online*
IndustryArena Forum > Community Club House > Computer Technology > USB, RS232, PARALLEL etc > WHAT PCI PARALLEL ADAPTER CARD WORKS BEST WITH WINDOWS XP
Results 1 to 6 of 6
    Nov 2007
    361
    Hello everyone ,
    Let me explain a little bit about what brought this subject up . I have a cnc router with a hp a1140n desktop pc with onboard printer port and it all works well with Mach3 and the router . I wanted to add a manual pulse generator (MPG) to make touching off with edge finder and trimming in holes...etc easier. I bought a mpg off ebay and I bought a Startech port pci parallel adapter card part# PCI1PECP after getting everything wired and hooked up and Mach3 configured the mpg will not work the selector switches work sometimes and the dial rotary encoder has never worked . I have got another mpg coming because the 1st one I got was bad . So the whole point to this story is when I turn off the computer somehow someway the configuration of this pci card changes itself . I'm not sure how or what is going on but has anyone else experienced this problem and what adapter card is recommended for using with a mpg ??? I downloaded a program that let's you change and monitor the pinout and this is how I found out the pci port was changing. Does anyone have any suggestions or help
    Re: WHAT PCI PARALLEL ADAPTER CARD WORKS BEST WITH WINDOWS XP
    Nov 2007
    361
    Ger21 do you know of anyone that has this card and what is do they use I have windows xp
    No.
    Oct 2005
    1145
    In teh LPT port setup you should be able to LOCK teh config so that windows does not change it on startup and it will always be teh same each time you start .
    Just a thought (;-) TP
    Nov 2007
    361
    Quote Originally Posted by vmax549 View Post
    By chance would you know what the lock option is or where ? Ir does it lock itself after setting it?
  1. Amazon PCI Parallel Port Card That Works
    By aunder in forum Mach Software (ArtSoft software)
    Last Post: 10-10-2018, 03:03 PM
  2. parallel port to laptop express card adapter
    By rewa2 in forum Want To Buy...Need help!
    Last Post: 09-22-2013, 03:09 PM
  3. Parallel port adapter help.
    By Rocco85 in forum DIY CNC Router Table Machines
    Last Post: 03-13-2010, 11:12 PM
  4. ExpressCard Parallel adapter?
    By GMTool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-25-2008, 05:41 AM
  5. usb to parallel port adapter
    By mmech in forum CNC Machine Related Electronics
    Last Post: 03-09-2006, 08:58 AM
