585,974 active members*
4,304 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Some problem saw operation
    Mar 2018
    6
    Hey guys,
    I use the scm post processor.
    With a morbidelli 5x prism.
    I have some problems with the nc output when applying a sawing operation.
    Do more people suffer from this?
    Does anyone have a solution for this?
    I am testing something with the TPD of the saw.
    Does anyone have a list of data that each number for function gives to the saw?
    I would like to hear from you
    Apr 2015
    327
    Re: Some problem saw operation
    Hello,
    which problem you have? Output is as a XPL for a tilt plane? Im ussually set saw blade on this machine as a router tool. Because problems with a use XPL and XG0 ... for a tool set as saw blade.
    Not sure what is exactly your problem
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Mar 2018
    6
    Hey,
    When I apply a saw operation inalphacam and export as pmg.
    then I get another operation onthe machine (look maestro)
    do you know a solution for this?
    I like to hear from you.
  1. NC studio operation (Restart Problem)
    By Somrit in forum Questions or Problems
    Last Post: 12-02-2018, 06:49 AM
  2. Operation Panel Problem
    By PDZ in forum Fanuc
    Last Post: 11-12-2018, 10:29 PM
  3. Problem With Turning Operation, Pls Help!
    By reavervon in forum EdgeCam
    Last Post: 06-05-2012, 11:04 PM
  4. Problem with pauses in drill operation
    By LuckyStrike in forum SprutCAM
    Last Post: 01-15-2009, 08:43 PM
  5. Drill operation problem
    By nomodoh in forum CamBam
    Last Post: 07-27-2007, 03:56 PM
