585,679 active members*
5,790 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Persistent libraries?
    Oct 2006
    51
    Every time I go back to the tool selection it has reverted back to mm. I have set up inches. Same with post Processor library. I have to keep switching it back. What am I missing?
    Dec 2011
    97
    Re: Persistent libraries?
    I don't have the answer, but I have seen a similar issue after setting the Tool Library in Options..Machine. madCAM sporadically changes the tool library to the default location instead of the one I have set.
    Hmm. It is possible I hadn't saved the setup to the machine.
    Mar 2016
    18
    I have the same issue
  1. Questions! -TOOL Selection Persistent - Load File and run with Script
    By designery in forum UCCNC Control Software
    Last Post: 09-18-2016, 12:28 AM
  2. Persistent Haas alarming
    By tyguidry in forum Haas Lathes
    Last Post: 01-16-2015, 11:17 PM
  3. Tool Libraries
    By SomeWhatLost in forum CamBam
    Last Post: 02-21-2013, 02:39 AM
  4. Intermittent (but persistent!) G540 fault light
    By TiagoSantos in forum Gecko Drives
    Last Post: 08-02-2012, 08:23 PM
  5. Operations Libraries
    By thebowman in forum Mastercam
    Last Post: 12-02-2009, 04:43 PM
