585,759 active members*
4,087 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > UC300ETH ETHERNET MOTION CONTROLLER?
Results 1 to 11 of 11
    Jan 2012
    163
    think I have decided to go with UC300ETH I have a question what else do I need to buy a long with it too:
    5LPT-UC300 Motherboard
    +5vdc @ 3 Amp 15W AC/DC ENCLOSED SWITCHING POWER SUPPLY
    is there anything else??
    do i need to have : C11G - Multifunction CNC Board too?
    Sep 2019
    197
    Re: UC300ETH ETHERNET MOTION CONTROLLER?
    Another option is the AXBB-E...it has the bob included plus its 24V i/o. The same motion controller than the UC300ETH
    Jun 2015
    943
    Quote Originally Posted by rmachinist View Post
    You can also use the UCSB CNCdrive - motion controls or UCBB breakout board CNCdrive - motion controls
    Aug 2015
    142
    I agree with eriks , but there is not so many i/o and its more compact than uc300eth.
    What are you going to drive your steppers with?
    Because something like an MX3660 or Gecko G540 will have your BOB built in.
    In my machine I have both an MX3660 and Gecko G540, all runing off the UC300eth-5lpt. I also have a C10 Bi Directional BOB. Then there are all sorts of other items as well. Compact? No. But it does work.
    UCCNC is my preferred setup now, but I used Mach3 (and still do occasionally) very successfully for years with the same hardware.
    Jan 2012
    163
    yea i was looking at the AXBB-E i think it would be a great option too all in one board is a plus,
    Jun 2015
    943
    It depends on how many I/Os will you need?
    The UC300ETH has lots of them, but you need a breakout board or boards to connect your sensors and switches and buttons etc.
    The AXBB-E has less of them, but you do not need a breakout board because the AXBB-E has the breakout board inside.
    You'll need a breakout board for each port that you want to use on the 5LPT board.
    Or, you can use a breakout board like the UB1 which the UC300ETH plugs into.
    Jan 2012
    163
    I think all i need right now is 3 limit switches for X,Y,Z , e-stop, alarm , and maybe a hand pendent, and later on cycle start button, i think for now i could use a x-box controller for the pendent
    Many pendants are USB, Xbox included.
    You can wire those switches to a single input too.
    If that's all you need, then the AXBB-E or UC400ETH are probably a better choice.
  1. ETHERNET MOTION CONTROLLER
    By maellaguitars in forum Stepper Motors / Drives
    Last Post: 01-31-2016, 08:03 PM
  2. Is the Ethernet SmoothStepper still the best motion controller for Mach3/4?
    By DingbatCA in forum Controller & Computer Solutions
    Last Post: 12-02-2015, 05:48 PM
  3. Which USB/Ethernet motion controller for a laptop?
    By ChrisAttebery in forum Mach Software (ArtSoft software)
    Last Post: 05-06-2013, 12:01 AM
  4. Ethernet Connection, Motion Controller, Mach3, New !!
    By Robiz in forum News Announcements
    Last Post: 03-28-2012, 04:59 PM
  5. CSMIO/IP-S Ethernet Motion Controller (CNC)
    By CNC support in forum News Announcements
    Last Post: 10-26-2011, 10:57 AM
