Hi folks:
I have worked along with the lead engineer in Ruida and came up with a new patch for the R6445G. With the new patch (only for the R6445G or our R6 DSP controller),. it should allow you to use the 4-axis (U -axis) to control a rotary. We're an alliance of Ruida and an authorized distributor.
I have made the same request to all other card manufacturers before; Trocent AWC708, PH T9, and one more to go, the TopWisdom A20.
With the new patch (only for the R6445G or our R6 DSP controller), it should allow you to use the 4-axis (U -axis) to control a rotary. In the past, you have to disconnect the Y-axis, load different a profile, then enable the rotary. After rotary work completed, you reversed the procedures to enable the Y-axis again. What a tedious task!
You can download it from our support link: *Update: Rotary support Patch for Ruida R6445G DSP laser controller * - Lightobject.com Support Forum
Marco - the Lasermintor (I'll be back!)
LightObject Laser
