585,996 active members*
4,725 visitors online*
Results 1 to 14 of 14
    Jan 2020
    6
    TNG v2 tool change/measure issue
    I am running TNG v2 12/20/19 update. The issue I'm having is when I have a tool change in my gcode (T2 M6) It begins the process and goes to my fixed sensor location, but then it rapids down and hits my sensor and stops.
    Then I have an error that says something like sensor triggered but not expected. The strange thing is when I click the Tool offset/measure, in the menu tool bar, it works just like it should. Please help me understand what is going on.This is driving me crazy.
    Mar 2017
    1312
    Re: TNG v2 tool change/measure issue
    Export and send me your profile .zip file.
    Jan 2020
    6
    Sorry, I'm not exactly sure what you're asking for. Script?
    Mar 2017
    1312
    Go to menu "File/Export Profile".
    Jan 2020
    6
    I'm sorry, this is the first time posting and I don't know how to send you my file. I do have it, but not seeing how to upload to you. Sorry for being so ignorant.
    Jan 2020
    6
    I figured it out. Here is the file.
    Mar 2017
    1312
    You have ATC enabled. I'm pretty sure you do not want to use ATC in your case.
    Jan 2020
    6
    Quote Originally Posted by PlanetCNC View Post
    I have had it both ways with the same result. Any more ideas. Thank you for your prompt replies.
    Mar 2017
    1312
    Position setting is not sensor position, it is position where you want to change tool. Set Z to 140mm.
    Jan 2020
    6
    That solved it! Thank you so much!! I knew it was something simple I just overlooked.
    Apr 2015
    Exclamation Re: TNG v2 tool change/measure issue
    Hi, I'm Diego, I have the same problem with TNG V2.
    I attach my profile file.
    I used this sequence with old software im my CNC:
    1) Fiend HOME (Machine coordinate HOME X=5 Y=5 Z=-5 on left angle and top of the CNC)
    2) Measure length of the first tool (Offset) withi fixed tool sensor
    3) Mesure Zero of material. X, Y manual definition and Z with mobile tool sensor.
    4) Start GCode program
    5) I do manual change tool
    6) Measure length of the new tool (Offset) withi fixed tool sensor
    7) Start new GCode program
    Now it doesn't work. The offset mesure NO correct.
    Please HELP me.
    Best regards.
    Apr 2015
    Please #PlanetCNC. Can You help me? This is a big problem for me.
    Best regards.
    Diego
    Aug 2020
    131
    The Tool Offset Measurement with the Option "Set Offset" did not work for me as well. I'm using "Set Tooltable" as I'm using a tooltable anyway and this works fine.
    Maybe give this a try.
    Mar 2017
    1312
    Correct configuration depends on your machine and G-code.
    If G-code uses G43 then "Set Offset" will not work. G43 will reset it. "Enable Offset" should be disabled.
    If G-code does not use G43 then "Set Offset" is preferred and "Enable Offset" should be enabled.
  1. Okuma 600 MA tool change issue
    By rpape2601 in forum Okuma
    Last Post: 08-23-2018, 03:07 PM
  2. tool change issue
    By Diedesigner in forum Uncategorised MetalWorking Machines
    Last Post: 01-26-2013, 05:56 PM
  3. Arrow 750 tool change/tool carosuel issue
    By Insept in forum Cincinnati CNC
    Last Post: 10-22-2012, 01:31 PM
  4. tool change and measure tool lenght, macro?
    By Charon in forum Mach Wizards, Macros, & Addons
    Last Post: 03-20-2012, 06:56 PM
  5. Tool change issue
    By GM81 in forum Fadal
    Last Post: 02-11-2011, 06:29 PM
