585,978 active members*
4,285 visitors online*
    Apr 2006
    4
    Shopsabre 4896 Z Drive
    Hello... I have a Shopsabre 4896 & my Z Drive stopped working. Does anyone know where to get the correct Mitsubishi drives? I contact Shopsabre and was told they do not support those drives any longer. I got one on ebay but didn't work. ANY Help appreciated.
    Jan 2010
    77
    Re: Shopsabre 4896 Z Drive
    First I would swap the signal wires from wincnc and make sure the step and direction signals are doing what you expect. If that's the issue you can rewire it and use different ports. Talk to Ben if you call them again. Another thing to consider is the drive requires programming. It can be done manually, if you look up the manual on it. If all that fails, I would swap the motor output wires on two drives and verify the motor,wiring, ect are all good. It's possible you have two bad drives, but swapping things around for testing will tell you. If your close to Houston and want help send me a pm.
    Quote Originally Posted by KMetcalf View Post
    I would recommend Contacting our team again, they may have misunderstood - while we may not sell that specific part but we can usually always retro-fit and help you get back to running especially if you have the part already.
    Sep 2013
    43
    did you get backup and runing i have a 4896 allso
  1. Replies: 5
    Last Post: 10-09-2021, 12:50 PM
  2. ShopSabre 4896 Z axis fail.
    By 2SManufacturing in forum Shopsabre
    Last Post: 04-23-2017, 07:23 PM
  3. ATC UPGRADE FOR SHOPSABRE 4896
    By parker711 in forum Shopsabre
    Last Post: 04-01-2016, 02:49 AM
  4. Please Help with Shopsabre 4896
    By awest486 in forum Shopsabre
    Last Post: 01-05-2012, 07:34 AM
