585,992 active members*
5,404 visitors online*
    Mar 2007
    215
    Question How to Switch Gears on a Lathe
    Had a repair guy come out and fix a problem I was having with my Wasino Lathe. He fixed it but left the lathe in low gear. I have never run it in anything but high gear and have no idea how to switch it. Is it a code you input into the control or a parameter or something else. Any help would be appreciated. It has a Fanuc 10T control. Thanks.
    Feb 2006
    992
    M41 high
    M40 low
    M code for each manufacture is little difference so check your manual.
    The best way to learn is trial error.
    Mar 2007
    215
    Yup, that did it. Thanks.
  1. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 06:25 PM
  2. Wanted Enco Lathe Model 110-0818 SWITCH
    By chrysler48 in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2011, 10:02 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
