586,024 active members*
4,401 visitors online*
    Nov 2010
    17
    TS 641 Repair/Parts
    Anybody ever worked on an old TS 641 probe? Model TS 641 IdNr 517 352-51 Probe is used on a Deckel Maho DMU-80 as a factory option.
    Our probe quit working and we checked with Heidenhain for a repair. They said they will no longer repair that model. I then looked around online to find another repair option. No luck so far. Heidenhain wants $6,000 for a replacement and 70 days for delivery(will come on a ship from Germany) unless we pay an extra $1,000 for express service.
    Since the repair option seems to be out I decided to start taking the probe apart since the other option is to throw it in the scrap bin. Upon opening, there was no leds lit up. I unhooked the 6 pin plug that goes to the stylus tip. After some looking around, VMM probing, and reassembly of the main board back into the housing, a red LED now flashes two quick flashes every 2 seconds or so. It seems to flash indefinitely until I plug the 6 pin plug from tip back into the board. Once I do that, the red light goes out. I am assuming there is something wrong/shorted inside the tip of the probe. I haven't exactly figured out how to successfully disassemble that part yet.
    My question is does anybody have that tip section to a TS 641 probe laying around? It bolts on with 4 screws. That may be my easiest option if somebody has a good tip section. Since the probe I have is worthless, I will continue to dive deeper into the tip I have and see if I can figure out how to get that section apart. Not exactly sure yet how that comes apart. I also assume the TS 641 is an optical sensor so maybe something on that circuitry in the tip is shorting out the board. I have no idea how that portion is assembled, so it may not be serviceable, but right now it is a $6,000 piece of scrap so nothing to lose.
    Also, anybody have an idea if a blinking red LED with 2 quick flashes every 2 seconds is a normal functioning main board?
    Attachment 434372
    Re: TS 641 Repair/Parts
    it's on stock and ready for shipment...
    https://e-cnc.se/collections/heidenh...ucts/517352-51
    I can't help you with the DIY repair
    Feel free to contact me....
    Best regards,
    Freddie Ourø Gaardbye
    [email protected]
    www.cnc-consult.dk
    Sep 2009
    99
    D_Turner,
    Did you manage to get your TS unit working? If yes how did you manage this? I have a similar unit needing attention at the moment!
    Best regards
    Jaideep
  1. cnc parts,DIY and repair costs
    By helpmeout in forum DIY CNC Router Table Machines
    Last Post: 04-26-2018, 12:57 AM
  2. Fanuc 6m, parts/service/repair still available?
    By diyengineer in forum Fanuc
    Last Post: 06-21-2016, 12:18 PM
  3. Repair and spare parts A2100
    By megaman26 in forum Cincinnati CNC
    Last Post: 05-02-2015, 05:40 AM
  4. Technical Repair Solutions (Midwest USA): Industrial Electronic Machine Repair
    By TechnicalRepair in forum Manufacture Company Listing
    Last Post: 11-04-2014, 09:04 PM
