585,575 active members*
3,512 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Help..ATC- keeps Spinning- Doesn't stop-Richmond VMC
    Jan 2020
    Friends..
    Need urgent help.Have a Richmond VMC 15year old(Taiwan make) with fanuc oimc.
    The tool changer arm keeps spinning continuously.Doesnt stop at tool changer positions. Please view the attached video.
    If the arm is operated with tool in spindle and do a tool change it stops with overload once arm goes to spindle.
    Won't be able to reset thru reset button,needs resetting pressing emergency stop.
    The frot magnetic sensors on the slotted cam are good.The contactor is always gets engaged,the relay is good. Has anyone had similar issues.
    Thanks in advance
    Aug 2009
    1570
    Re: Help..ATC- keeps Spinning- Doesn't stop-Richmond VMC
    Wel..come
    Jun 2005
    1729
    You did not upload your video. This sounds like either a bad sensor or the input the sensor is attached to is not firing correctly.
    Russ
    Hello, What control does your machine has?
    I have missing the O9001 macro for tool change. Can you share it?
    My email address is [email protected]
    Thank you
    jolulank
    Quote Originally Posted by Roncad View Post
    Friends..
    Thanks in advance
    www.doctornumerico.com
    cnc physicians
