Scripting a Profile operation with stock to leave seems to be ignored. The profile toolpath is created as if stock to leave was 0.
When using the dialog it works properly.
If you script it and then regenerate with the dialog it still does not work. Howver if you delete "Stock To Leave" and re-enter it then the profile operation works properly. The scriping profile operation will then also work properly for the duration of the session.
Thanks,
Curt
