585,556 active members*
3,579 visitors online*
    May 2016
    TNC 155Q Problem
    Hello, i'm from Spain. Sorry for my english.
    I have a mill with tnc 155q controller. When I turn on the the machine, i have this issue.
    https://youtu.be/jAdl6StGLnI
    ¿What can be?
    Thank you.
    Apr 2015
    170
    Re: TNC 155Q Problem
    It means the memory checksum does not match. probably caused by a flat battery, you will have lost your programs and parameters as well as your tool table and offsets.
    May 2016
    Quote Originally Posted by Bdrangdo View Post
    Thanks for answering.
    I changed bateries and nothing has changed.
  1. load the MP after battery is empty TNC 155Q
    By Wulfi in forum HEIDENHAIN -> TNC
    Last Post: 08-17-2011, 08:28 PM
  2. TNC 155Q matchmaker parameter Problem
    By Zoni in forum DNC Problems and Solutions
    Last Post: 08-31-2009, 08:21 AM
  3. TNC 155Q matchmaker parameter Problem
    By Zoni in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2009, 10:31 AM
  4. Philips 432 / Heidenhain TNC-155Q
    By HS-Cutter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-03-2009, 02:18 PM
  5. Heidenhain 155Q Problem with x and Y axis
    Last Post: 04-05-2008, 10:33 AM
