585,886 active members*
5,945 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Axis controller not responding to NC
Results 1 to 7 of 7
    Dec 2012
    Angry Axis controller not responding to NC
    Need help. I'm getting an alarm of axis controller not responding to nc . I swapped out my 1010 cards and it stayed the same then swapped the Amps, same problem.The alarm on the DI/DE reads all three axis's but I can run x and z without an issue. Y axis servos out, then when I go to jog out in Y it wont but in x it "pops" kinda like a jammed motor?? Can I swap out the x and y motors and see if it transfers to the x axis or not? Oh ya Im working with a 89 2040. Thanks for any info you folks can give me
    Jan 2015
    417
    Re: Axis controller not responding to NC
    Yes the X and Y DC servo motors are the same. Did you actually Pull the card and re-seat them into the motherboard.
    Jan 2015
    417
    The pop u hear is probably the execution of the pulses that you tried jogging the Y unsuccessfully and when you switch to the X it jumps. Are you getting any other Error codes numbers?
    Jan 2015
    417
    You can also when the machine is off pull the connections going to the Y-axis card and plug them into the X and vise versa Your X will become Y and your Y will become X
    Dec 2012
    Yes I did, and cleaned all the contacts with a eraser, that and pulled and swapped the Amps. Thanks for letting me know on the motors am going to try that this morning.
    - - - Updated - - -
    No other error codes at all
    Jan 2015
    417
    Just talked to my brother which worked on the Fadal control at Fadal and he said it is not the Amps or the motors. it is strictly a software and or electronics issue between the control and the card. Do you have another fadal that you could swap the 1030 card with? or the 1400 card?
    He said to try this zero out your Backlash First type BL to get the back lash write it down. And then do the BL,1,0,0,0 and then BL,2,0,0,0 and then BL,3,0
    How long has it been doing this?
    Jan 2015
    417
    It could also be the socket on the MotherBoard
