585,753 active members*
4,020 visitors online*
Results 1 to 8 of 8
    Apr 2015
    16
    Siemens 810D tool offset
    Can anyone help out, the tool offset datum every now and then will change datum from Z to Y which causes problems setting tool offsets and the only way i know of getting it back to z datum is to power down the machine and traverse datums.
    See attached JPEG.
    Thank you
    Re: Siemens 810D tool offset
    Is that a horizontal milling machine?
    Apr 2015
    16
    Quote Originally Posted by sabregr View Post
    Hi,it is a Vertical milling machine.
    Are you able to give a solution?
    Thank you.
    Aug 2009
    1570
    what G code do you have active G17..G18...or G19 ?
    Apr 2015
    16
    Quote Originally Posted by machinehop5 View Post
    Hi machinehop5,
    I have attached a jpeg of machine OFFSETT this has never altered by myself so has always stayed at what ever offsett is showing.
    Apr 2015
    16
    Hi again machinehop5,
    I have also attached a jpeg of active G code when running machine.
    Thank you.
    Aug 2009
    1570
    Quote Originally Posted by johnyj View Post
    Odd behavior...I wonder if, you have a sticky button or Keyboard problem going on.
    Sep 2002
    1954
    The tool offsets depends on the type of tool (milling or turning tool) and on the active plane selected by the G-Code G17 / 18 / 19.
    For a milling tool the tool length is defined in Z with G17. That's the default case.
    If you observe that the tool length sometimes is effective in Y instead of Z I would expect that you changed your active plane from G17 to G18.
  1. offset for internal threading tool on siemens 840d SI
    By moriocka in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-21-2018, 08:37 AM
  2. Siemens CNC 810D Tool Turret Problem
    By kmarsus in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 04-12-2016, 07:43 PM
  3. DMG DMC1035 SIEMENS 810D ERROR CODE 700141 (Will not tool change)
    By scottbryce in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-26-2015, 08:46 AM
  4. Fadal 6535 with Siemens Sinumerik 810d control doesn't recognize the tool
    By Mr.Peet in forum DNC Problems and Solutions
    Last Post: 06-25-2015, 02:46 PM
  5. Siemens 810d - V24 to USB
    By MikeE25 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 03-28-2012, 05:04 PM
