A friend is helping me through an upgrade of a small cnc project. It actually didn't work when I got it and with mach 3 / windows support becoming complicated, decided to change out some items.
The motors and controller for the project are on a test board for convenience and we can now move all 3 axis with on a bench.
Before we transfer it onto the cnc, I would like to add some limit switches to reduce the risk of damage.
If possible, it would be nice to also have a way to go to a (0,0,0) position, but that is not an absolute priority right now.
Any suggestions on some limit switches ?
This is a hobby. I want it to be reliable, but don't want to spend $100 / switch either.
I prefer to not buy from ebay if possible.
Thanks for any insights.
Harry
Misc info for the curious:
- MK3/9
- software license
- MPG pendant and adapter
- 10 pin header adapter
- 16 pin header adapter
- various shielded USB cables, and wires
- 3 each of the gecko 213V stepper motor drivers
- 3 stepper motors
- 48 volt power supply, etc
In case it matters, it is a small moving gantry system.
- about 3x4 ft x ~ 4-5 inches of z
- palm size router attached
- The linear motion parts are just the hobby grade cnc router parts carriages, so not a precision setup
- nema 23 size stepper motors
- lead screw - looks like an acme thread
- single motor and drive on each axis
- 8020 type construction
Plans
- Routing some 18mm baltic birch with joints
- Drilling holes
- Possibly some plastic hole drilling
- Goal is +/- 1mm overall dimensional accuracy results on a 20 x 30 x 3/4 baltic birch ply ( ~ 500 x 700 x 18mm ply)
Not sure if that is possible or not with the linear motion components and framing or not, but will have some fun playing with it.
Harry
