585,665 active members*
3,119 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > What is the bearing size for FK10 ballscrew supports?
Results 1 to 2 of 2
    Feb 2014
    Question What is the bearing size for FK10 ballscrew supports?
    Hello all,
    I am trying to find the bearing sizes for FK10 and FF10 ballscrew supports. You can buy those on the cheap from Chinese manufactures, but they come with radial bearings. I want to replace the FK10 bearing with angular contact one, but am unable to find the size. All I know is the ID is 10 mm. So if anyone has this info, please post it.
    I am aware that some sellers on Aliexpress and Ebay are offering a version of the ballscrew supports with angular contact bearings pre-installed. However, as I have had bad experience there, I would like to source and replace the bearings myself - just need the correct size/type.
    And lastly, I know I can find a lot better quality supports from brand name manufacturers on sites like Misumi or McMaster, but I can't afford those...
    Thanks!
    Nov 2013
    4358
    Re: What is the bearing size for FK10 ballscrew supports?
    I found this in a THK publication. It suggests 7000 bearings, 10 x 26 x 8.
    Craig
