586,009 active members*
4,941 visitors online*
    Dec 2009
    73
    ADTECH CNC4640 can't read from usb
    A friend has asked for help with his cnc router, he is unable to load programs from the usb drive.
    The machine was shutdown over the holiday period, and on return it no longer reads from the usb drive, the response from the system is "can't open catalog"
    We have tried:
    Reboots
    Using different usb drives, formatted fat32 and ntfs etc.
    Replaced the usb connector
    using the SD card slot
    On bootup:
    system ver: 0.7.09
    Hardware ver: 2.0
    I have no experience with this controller so looking for any guidance available, i'm currently trying to find the correct manual and will also look at hooking up to a laptop to transfer programs via network port, all help appreciated.
    Dec 2009
    73
    Re: ADTECH CNC4640 can't read from usb
    Thanks Admin for moving this thread, I wasn't sure where best to post it.
    Dec 2009
    73
    Also interested if anyone uses the network port for file transfer. I'm hoping its a viable option
    Sep 2015
    Quote Originally Posted by compfranon View Post
    Not sure if you got an answer to this but I use the software at the link in my OneDrive. Took a while to work it out and get it to work but it does now with great results. Check Chapter 7.1.2 in the PDF for setup.
    https://1drv.ms/u/s!AhDYD0_HVekngQEI...0L4rc?e=XcBetS
    Can you let me know when you've copied them so I can remove the link please.
    We have tried:
    Reboots
    On bootup:
    system ver: 0.7.09
    Hardware ver: 2.0
    After all you have done above, seems the problem comes from the CNC4640 itself.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. plasma touch off for cnc4640 controller
    By John Shand in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-30-2020, 05:39 AM
  2. seting up ADTECH CNC4640 ATC
    By glrjola in forum Auto Tool Changer
    Last Post: 12-28-2017, 11:22 PM
  3. ADTECH CNC4640
    By CJF in forum Fanuc
    Last Post: 05-15-2015, 03:04 PM
  4. ADT-CNC4640 4 Axis Milling CNC Controller
    By adtechcn in forum News Announcements
    Last Post: 01-07-2013, 09:30 AM
