585,764 active members*
4,475 visitors online*
Thread: A Axis
    Oct 2019
    20
    A Axis
    I have added a stepper motor to my machine and enabled it as axis "A" in mach 3, Does anyone know how I can get the "A" axis stepper motor to rotate continuously? using G-Code? How can I set the speed? I have a stepper motor that has 0.6 Degrees per step.
    Apr 2004
    5735
    Re: A Axis
    If you want to do 4-axis machining, simply mounting a stepper to your mill's bed isn't going to help much. You really need a rotary table with a substantial gear ratio to withstand cutting forces that will tend to overpower the stepper. G-code commands don't tell steppers to rotate continuously, although you can direct it to advance to a large number of degrees. If you wanted continuous motion, it would be better to set it up as a spindle rather than an axis, and use M-codes to control it, using PID to set the speed. Usually a different sort of motor would be used for that, not a stepper. Or you could start with a lathe rather than a mill or router.
    Andrew Werby
    Website
  1. Replies: 1
    Last Post: 01-28-2024, 06:26 PM
  2. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  3. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  4. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  5. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
