585,992 active members*
5,238 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach 4 > How do I control the feedrate/jogging speed arrows with a keyboard?
    Nov 2015
    8
    Greetings,
    I am trying to control the arrow keys that will increase or decrease the jog speed with a keyboard. I'm quite stuck and could use some help. Thanks!
    Apr 2004
    5737
    Re: How do I control the feedrate/jogging speed arrows with a keyboard?
    Normally, the jogging feedrates are set in Motor Tuning when you indicate velocity. If it goes a lot slower than that, you might have a slow jog feedrate active. Hit the Tab key and see what it says under "Slow Jog". If it's less than 100%, you can change it with the slider. If you like having a slow jog rate sometimes, you can set it to a lower percentage, and hold down the shift key when you want to jog fast, which should make it revert to the master velocity.
    Andrew Werby
    Website
  1. Jogging keyboard dxf
    By schesby in forum PlanetCNC
    Last Post: 01-01-2020, 06:14 AM
  2. Mach 3 Keyboard control feedrate with 6 axis pendant.
    By ballistic42 in forum Mach Software (ArtSoft software)
    Last Post: 04-03-2015, 09:34 AM
  3. Keyboard Arrows Problem
    By kolias in forum DIY CNC Router Table Machines
    Last Post: 08-15-2009, 10:31 PM
  4. Sluggish Keyboard Jogging
    By nelZ in forum CamSoft Products
    Last Post: 10-20-2008, 08:42 PM
  5. Delayed keyboard jogging
    By alfalfa in forum CamSoft Products
    Last Post: 08-13-2008, 05:18 PM
