585,687 active members*
4,196 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Hole machining cycle
    Feb 2008
    6
    Hi, I am trying to machine a part using a hole machining cycle. I have 4 holes that are drilled .125" and I am using them with pins to locate the part on a fixture. What I am trying to do is use a hole machining cycle with a .155" end mill to machine the holes to .187". What it does is give me this message (MSG, Cycle doesn't supported) when I post the part. I am using SC 11.
    Art
    Aug 2009
    1570
    Re: Hole machining cycle
  1. Tap Hole drill cycle much deeper than desired
    By Rotax91 in forum BobCad-Cam
    Last Post: 08-31-2015, 06:51 AM
  2. Edgecam hole cycle issue
    By docdesigns in forum EdgeCam
    Last Post: 07-01-2013, 02:47 AM
  3. Hole Machining - Deep Drilling Cycle in Sprutcam
    By kfwittekiend in forum SprutCAM
    Last Post: 11-19-2012, 01:04 PM
  4. G70 Bolt Hole Cycle
    By ZedB in forum G-Code Programing
    Last Post: 09-11-2012, 03:11 AM
  5. Modify Hole Cycle
    By tummen in forum EdgeCam
    Last Post: 08-23-2010, 07:02 PM
