585,663 active members*
2,973 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Making Z axis not lift all the way up everytime.
    Aug 2016
    43
    Hi All ,,
    I am making some upgrades for my cnc and thus im milling holes into aluminium to make the sides for my gantry.
    Right now its taking me about 1 hour for each hole , but im thinking i could reduce that time alot if i could make it only lift about 2mm over each pass height to clear the chips instead of lifting to safe zone that is 5mm over the workpiece..
    im making holes 9.5mm with a 4mm single flute endmill..
    Any ideas on how that would be possible are appriciated as im still in the learning process " 1.5 years now ".. he he
    Best regards ,,
    Kristjan
    15362
    Re: Making Z axis not lift all the way up everytime.
    Quote Originally Posted by Kristjan1505 View Post
    Hi All ,,
    Best regards ,,
    Kristjan
    Post the main line of code and I will correct it for you here is an example in inch
    G73G98X1.Y1.Z-.200R.1Q0.1F8.
    G98 will act with R value when the cycle is finished and lift the Z axis up by this value
    Q is the peck or chip break you want to use
    G83G98X1.Y1.Z-.200R.1Q.01F8.
    This will lift the drill out of the part by the Q value while cutting
    After the cycle is finished it will move the Z axis up by the R value
    Mactec54
    Aug 2016
    43
    Hi Mactec , and thx for the reply ., sorry for the late answer though.
    As i am a total noob when it comes to code , i must say i have not the SLIGHTEST idea where to find it , or is it just the ncp file i use to send to my cnc ?
    Best regards ,
    Kristjan
  1. Reset Zero Axis everytime
    By KenR60 in forum Chinese Machines
    Last Post: 06-24-2016, 03:00 AM
  2. Vertical lift platform-vertical lift table in China
    By mornlifttable in forum News Announcements
    Last Post: 06-28-2012, 04:30 AM
  3. Z Axis Lift
    By kolias in forum DIY CNC Router Table Machines
    Last Post: 05-29-2009, 11:36 PM
  4. Z-Axis...but for Router Lift
    By jallenmorris in forum Want To Buy...Need help!
    Last Post: 01-06-2009, 06:46 PM
  5. Putting Z Axis CNC on Quill Vs Z table lift
    By Klean-Power in forum Bridgeport / Hardinge Mills
    Last Post: 03-26-2006, 10:11 PM
