585,981 active members*
4,288 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Boss 8 CNC retrofit and 5 HP upgrade - Build thread
Page 2 of 3 123
Results 21 to 40 of 59
  1. #21
    Jan 2006
    204
    Re: Boss 8 CNC retrofit and 5 HP upgrade - Build thread
    Quote Originally Posted by mongoose View Post
    post up some pics.. maybe !
    yes pictures
    and im subscribing
  2. #22
    Dec 2011
    155
    So i got a bit of rust on the x ballscrew where bridgeport had an open are under the table. I have some bronze wool and some citric acid coming in. I figure ill try to get the rust off, and may even polish afterwards, not sure here. Its a $1000 mill so not sure how much it makes sense to spend on it. The screws seem like they are in very good shape otherwise.
    Attachment 437034
    The ways on the table look like there is very little wear and cleaned up nice:
    Attachment 437036
    One area I have been debating with myself is weather or not to replace all the way oil meetering valves. This mill is 25 years old, but clearly low hours. I have looked, and there are a ton of these things. I'm sure Id spend 500+ to replace them all. thoughts?
    Boss 8 belt size with servo:
    y axis 240h100 gates
    .5 pitch, 1" width, h belt, 24" long, 48 tooth
    x axis 220h100 gates
    .5 pitch, 1" width, h belt, 22" long, 44 tooth
    z axis 270h075 gates
    .5 pitch, .75" width, h belt, 27" long, 54 tooth
    Anyone know if the timing belt on the spindle low gear is the same a regular Bridgeport?
    The coolant chip guard is the same as this one:
  3. #23
    Dec 2006
    87
    Quote Originally Posted by dbsharp View Post
    https://www.youtube.com/watch?v=AX7d...ature=emb_logo
    Looks like its in great shape ! i would think if you see a ALL the ways being lubed you should be good.. or possibly figure a single point hookup before each metering valve ... and you could do a good visual since the table is off..
    would be interested in the chip guard if the price is right.. pretty simple design tho... could possibly make one as well...... lmk !
    thanks
    Joe
  4. #24
    15362
    Attachment 437034
    Attachment 437036
    The Belt is a regular Timing Belt just measure it and you can get a replacement I may have one if you have the size that you have
    That C3 Ballscrew does not look so good with the rust on it, it looks like it has never had enough oil on it which can be a problem with the standard oil pumps on these machines
    Here is a photo of my table guard I made from 1/8" Aluminum sheet the corner posts where milled from bar stock the 2 ends just slide in which you can remove for long parts
    And Y axis Ballscrew after more than 15 years of use it does have custom way covers though
    Mactec54
  5. #25
    Dec 2006
    87
    Mac, do you recommend upgrading the machine oiler to some other method ? is your chip guard mounted in the t slots like the oem unit ?
    thanks !
    JOe
  6. #26
    15362
    thanks !
    JOe
    No the Guard if mounted to the back flange of the table on the inside so the drainage and all T slots are clear along the back, this only works if you have the Boss Tables it has 3 1/4-20 SS screws that hold the back it in place and the corner posts have 2 10/12 tpi SS button head screws as well, it gives you the full table to use
    Yes the oilers need to be replaced the one's I have used are not cheap but run at 170 PSI 150 PSI is ok like this pump here they are every where so you can some times find a good price
    https://www.ebay.com/itm/202834043075
    Mactec54
  7. #27
    15362
    thanks !
    JOe
    Just did this close up for you to see how it is mounted
    Mactec54
  8. #28
    Dec 2006
    87
    thanks for the pic Mac... well as far as the oilers are concerned i actually dis-assembled the Bijur cleaned it thouroughly, changed the filter and tested it completely.. you have to be careful as some of the motors ( which look alike ) and all of the complete pumps pump at different rates... due to the timings of the pumps... and there are adjustments to the stroke of the pump.. and finally i bench tested it for 2 days and measured the output...
    now, this prompted me to look at my 2 boss' y screws... ( both machines are in a state of construction and havent been used in years... )
    so this made me think that maybe db's machine is just rusty from sitting .. possibly outside ? as we find many of these machines outside in the elements.. or in a un conditioned building...
  9. #29
    Dec 2011
    155
    I think that's the case it sat for quite a while, I have had it for 4 years and the guy beforeme had it for a long time too. The ballscrew looks great except for the one section next to an opening where moisture could get at it more directly. I took brass wool to it and got off as much as possible, the nut moves smoothly through that section so I'll let it go as is.
  10. #30
    Dec 2011
    155
    Ive been plugging data into the calculator at https://www.servotak.eu/tools/engineering_calculator
    Now I'm starting to think that the 400w DMM servo would also be a good match for the boss. this is showing what each would do assuming 500kg mass being moved, and this is probably a bit higher than what I'd use unless I had a heavy 4th axis up there. The 400 wat motor is seeing a 5:1 inertia ratio. the 750w motor is seeing a 1:1 both supposedly are good. here you can see the machine force each would support. I suspect I wouldn't exceed the force the 400 wat motor can support.
    thoughts?
    400w:
    Attachment 437990
    750w:
  11. #31
    15362
    thoughts?
    400w:
    Attachment 437990
    750w:
    In theory and calculations are good but not always give you the right answer 750W is what you need for this machine I have used the 400W on another mill but needed a 2:1 gearing on the same pitch screw to make it work, and the Boss is a much heavier machine to move than the small Jet Mill I use the 400W on, so I would not go that route, they won't have enough power / torque to get your machine working how it should
    A 400W motor will move your machine but will always be faulting out once you start cutting anything
    You missed one box Force Weight in those calculations the Tables are 450Lbs and the Saddle is 200Lbs
    Mactec54
  12. #32
    Dec 2011
    155
    Yea,
    I defiantly had the acceleration turned way down, using .25g acceleration the requirement goes up. It looks like with the 750 watt servoes, I would get about 700 lbs machining force while swinging 1100 lbs of table, saddle, parts, fixtures, and 4th axis around at .25 g
  13. #33
    Dec 2011
    155
    Ok lots of progress on this project. I have purchased 4 750w DMM servos w dyne 4 drives. I also bought all the broachs, reams, and pulleys so I can make pulleys and fit the new motors up. The electronic cabinet is cleared out and ready for the new parts.
    I have a pretty decent model of this machine now thanks to days of measuring and drawing:
    Attachment 439354
    Now to figure out the new servos:
    x:
    Attachment 439364
    y:
    Attachment 439360
    Attachment 439362
    Quill:
    Attachment 439358
    Knee:
    Attachment 439356
    For the Base I want to do something kind of like this:
    Attachment 439366
    And a chip tray for chips and coolant:
    Attachment 439368
    More on next Post.
  14. #34
    Dec 2011
    155
    Basic Idea of shape for enclosure, I'll add doors to it and a tube steel skeleton:
    Attachment 439370
    Did I mention I will also make the chip tray slide out from the bottom for easy cleaning? but I don't have that all designed yet:
    Attachment 439372
    I Also bought a graymills 1/2 hp coolant pump off ebay for a decent deal, and will make a coolant tank under the left side of the chip tray, saw some good ideas for it on a video about a off the shelf one.
    Suggestions? Comments?
  15. #35
    Dec 2006
    87
    looks like you are making some good progress !!! my build has been sidelined for the moment but following along !
  16. #36
    Dec 2006
    87
    as far as coolant tanks.. im going to use the one i got with the machine.. ill be building a chip tray similar to the oem version and just be using the 2 table drains
  17. #37
    Dec 2011
    155
    I think a tank like that would work great if your using a table chip guard and your not flowing more coolant that the table drains can handle. I think my 1/2hp pump could probably overwhelm the table drains. I'm thinking of drilling some extra ones so I can control the way it flows off the table.
  18. #38
    Dec 2006
    87
    Mactec, after wrestling with the bijur oil pump for 2 days im ready to concede and purchase this pump you recommend.. any idea if it is the 4mm or 6mm model ? it will be coming from china so i want to be sure i order the correct one also i am going to pull the table to check the oilers is there any info or schematic on what metering orifices will be needed?
    thanks
    Joe
  19. #39
    I have a mill thats in good condition with low hours originally servo driven. I will upgrade with MESA cards, Linuxcnc, modern servoes, 5 HP motor and VFD (variable drive removed), and maybe a full enclosure.
    My progress thus far is the 5 HP motor is installed and I"m about to fire it up. I also have the Mesa cards and mpg.
    PS I will be on the lookout for reasonably priced Kwik Switch 200 tooling. I may even make them from scratch at some point if I feel like doing a little tool post grinding, depends on if I can get what I want without paying inflated prices...
    Grab CAD link:
    https://grabcad.com/library/bridgepo...-vfd-upgrade-1
    Attachment 435014
    Attachment 435016
    Attachment 435018
    Attachment 435020
    Very impressive.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  20. #40
    Dec 2011
    155
    So its been a while since an update. I have mounted and made all the parts for x y and the knee for the servos. The Chinese timing belt pulleys I machined to fit my servos were total crap and I had to machine the teeth profile off of them and do a press fit with the original Boss pulleys I bored out. Now I am in the process of designing the actual parts to make the chip pan and enclosure I mocked up in previous post.
    Attachment 448346
    Attachment 448348
    Attachment 448350
    Attachment 448352
Page 2 of 3 123
  1. Upgrade from BOSS 3
    By 1875 in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2017, 07:52 PM
  2. Boss 10 Retrofit options / need Boss 10 Diagrams
    By panozeng in forum Bridgeport / Hardinge Mills
    Last Post: 08-25-2015, 06:47 PM
  3. Boss 5 upgrade
    By Tig-140 in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2013, 04:08 AM
  4. Boss 5 Upgrade
    By Meenbombs in forum Bridgeport / Hardinge Mills
    Last Post: 12-25-2011, 04:00 AM
  5. boss 5 retrofit
    By loose1 in forum Bridgeport / Hardinge Mills
    Last Post: 07-25-2010, 10:39 AM
