585,991 active members*
4,725 visitors online*
Results 1 to 6 of 6
    Jan 2012
    163
    driver fault?
    when using closed loop steppers the drive fault can that be wired along with the E-Stop?
    Nov 2012
    1267
    Re: driver fault?
    Not directly. E-Stop is typically a pair of NC contacts, and drive fault is typically an open collector output.
    You could wire all your drive fault outputs to a small auxiliary relay, and then wire that relay in series with the E-Stop.
    Jan 2012
    163
    Quote Originally Posted by CitizenOfDreams View Post
    I don't understand could you draw it out? Relay what one to buy?
    Nov 2012
    1267
    Re: driver fault?
    Something like this. Pretty much any small relay SPDT relay will work, as long as it has the right coil voltage.
    Jan 2012
    163
    Thanks I understand now. Pony tail all 3 drives to relay to the e-stop button to the bob
    Nov 2012
    1267
    Re: driver fault?
    Yep, that's it. Don't forget the diode to keep the drives safe from back EMF.
  1. spindle driver fault
    By freemanxxx in forum Bridgeport / Romi Lathes
    Last Post: 01-23-2014, 02:19 AM
  2. KL-4030 Driver Fault LED
    By dcl-inc in forum Stepper Motors / Drives
    Last Post: 09-12-2012, 06:10 PM
  3. Replies: 8
    Last Post: 09-09-2011, 02:01 PM
  4. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
  5. Msd556 Driver Fault
    By Oldmanandhistoy in forum Stepper Motors / Drives
    Last Post: 07-11-2006, 12:36 AM
