586,000 active members*
5,067 visitors online*
Results 1 to 6 of 6
    Jun 2017
    143
    TNGv2 Emergency stop
    Since my spindle and coolant are controlled by a separate I2C board and the controller doesn't know how to stop them when the emergency stop is hit I have disabled all options in Settings->Events->EStop.
    If I hit the Estop though it leaves my coolant and spindle buttons on (as expected), after clearing EStop I can then hit the coolant buttons to stop that, but hitting the spindle button does nothing and it stays highlighted. When the EStop originally hit the Active M-Codes shows a changes from M03 to M05 (I suspect this should not happen in this case). The only way for me to then stop the spindle is the issue a M03 commands followed by a M05 command in the MDI window. Using version 2020.01.17 at present.
    Have you given any more thought to being able to store a I2C sequence in the controllers non-volatile memory that it can send out when the EStop is hit? In my case I would want it to send 2 sequences of 2-3 bytes to turn both collant and spindle off.
    Simon
    Mar 2017
    1312
    Re: TNGv2 Emergency stop
    Please export and send me your latest profile.
    Jun 2017
    143
    Profile emailed to support.
    Simon
    Mar 2017
    1312
    I believe I just fixed this.
    Jun 2017
    143
    Nice work. I will check it out again in the next release and report back.
    Jun 2017
    143
    I have tested and can confirm this is fixed.
    Now I am just hoping you can find a way to allow some I2C commands to be sent on Emergency stop.
    Simon
  1. Problems with Emergency Stop/Stop function.
    By MrEmo in forum PlanetCNC
    Last Post: 10-19-2021, 10:47 AM
  2. emergency stop condition after E stop
    By Cosmin90 in forum Fadal
    Last Post: 01-14-2020, 01:30 AM
  3. Generic Emergency Stop (E-Stop) Design Concepts?
    By zipzit in forum CNC Machine Related Electronics
    Last Post: 06-09-2011, 12:14 PM
  4. Emergency stop
    By Franky42j in forum Philips
    Last Post: 08-20-2008, 03:16 PM
