585,712 active members*
4,045 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC 20 1993 Air line lubricator purpose
Results 1 to 6 of 6
    Mar 2013
    88
    Can someone please tell me the purpose of the air line lubricator in the box below the electrical disconnect?
    It’s the left bowl in the picture . The air line connects on the right side of the box, goes to a moisture trap in the right side of the box.
    The Oiler feeds the solenoids below the cabinet .
    Does the Oiler just lube the solenoids, or downstream
    What oil should I use?
    Thanks!
    Sent from my iPhone using Tapatalk Pro
    Oct 2008
    1632
    Re: Fadal VMC 20 1993 Air line lubricator purpose
    Most likely to keep moisture from corroding everything. I have driers and moisture traps and I still get condensation in my lines, but it's in a non-insulated shop so there are some pretty big temp swings.
    My Fadal only has a regulator / separator in that cabinet so I added another Filter/lubricator in front of the machine (A real one), and a 120 volt solenoid. When the machine is powered up, the air solenoid comes on and supplies air to the machine, when power is turned off, the air is turned off.
    On yours, that is the main inlet so the lubricator will supply everything, including draw bar cylinder, Hi/Lo cylinders, and orientation cylinder. That's a good thing as long as it's a very minimal amount.
    I'm using Marvel Mystery oil in the lubricator and I have it turned way down to a very minimum amount. I rather have a film of oil on my solenoid valves and inside my 4th axis than moisture.
    So far, so good.
    Mar 2013
    88
    Maybe I’ll just use air tool oil
    Mar 2013
    88
    I went with the Marvel oil. It’s red, easier to see in the sight glass, specs say it’s good for corrosion prevention.
    Thanks for the tip
    Oct 2008
    1632
    Glad I could help. I've used it for many years and had excellent luck with it.
    I have fewer problems with valves sticking since I've done that as well.
    Jan 2012
    it also lubes any air actuated device. The Hi/Lo shift air solenoids as well as the tool change / M19 spindle orientation air solenoid.
    Fadal calls for Mobil DTE lite oil.
  1. Replies: 4
    Last Post: 12-04-2018, 07:48 PM
  2. 1993, Fadal rotary table, M60 M61 solenoid question
    By Houndogforever in forum Fadal
    Last Post: 08-09-2016, 08:13 PM
  3. Control Retrofit for 1993 Fadal 6030
    By dunnitagain in forum Fadal
    Last Post: 07-19-2015, 11:49 PM
  4. fadal cnc 88 program limitation at line 734?
    By Runner4404spd in forum Fadal
    Last Post: 03-04-2009, 03:21 PM
  5. Future of Fadal product line
    By holedpiston in forum Fadal
    Last Post: 11-14-2006, 02:44 AM
