585,971 active members*
4,250 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Toggle coolant while peck drilling
    May 2010
    26
    I have a job where i’m drilling deep holes and i would like to have the coolant start briefly when i have retracted the drill bit.
    Is there a way to do this without writing my own drill function?
    I’m using G73 for making these holes.
    Full retract for every 8mm total lenght 400mm
    Frank
    Feb 2011
    353
    Re: Toggle coolant while peck drilling
    you will have to write your own drill cycle in order for the coolant to come on at every time it retracts to the R plane that you are using in the G83
    there is no way for the control to generate the coolant on / coolant off at each full retract
    Dec 2013
    5717
    Why not just run the coolant through the full drill cycle? That's the way I do it.
    Jim Dawson
    Sandy, Oregon, USA
    Exactly. Theres not really a good reason not to let it blast away.
    Oops... after writing this I just noticed I'm in a Turning section. Hope this still applies. At least partially. Was thinking mill. Sorry. (Head slap!)
    I've got a feeling the OP does not have an enclosed machine and is hoping to avoid a big mess.
    Just for fun... here is 1/4 of what might work. You would need to continue in kind down to Z-400. I tried to figure out how to write it with a small subroutine called multiple times with a built in on-the-fly offset change. Couldn't quite figure it out and didn't want to spend all day trying so I left it at this.
    Macro pros could probably come up with something much better then this.
    This is generic Fanuc based. May or may not need to repeat the position call X0.Y0.
    I'm about 90% certain this would work. Just not sure how the control will react with all the M and G4 stuff stuck in between drill attempts.
    T1M6 (YOUR DRILL OF CHOICE)
    G17G21G40G49G54G80G90G98
    G0X0.Y0.
    G43Z3.H1S2960M3T2
    M8
    G4P250 ---------(1/4 SECOND SPRAY. ADJUST TO SUIT)
    M9
    G98G81Z-8.R3.F450.
    M8
    G4P250
    M9
    X0.Y0.Z-16.R-7.
    M8
    G4P250
    M9
    X0.Y0.Z-24.R-15.
    M8
    G4P250
    M9
    X0.Y0.Z-32.R-23.
    M8
    G4P250
    M9
    X0.Y0.Z-40.R-31.
    M8
    G4P250
    M9
    X0.Y0.Z-48.R-39.
    M8
    G4P250
    M9
    X0.Y0.Z-56.R-47.
    ---------------(continue to 400)
    G80
    G0Z25.
    G53Z0.Y0.
    M30
    The other option. Needs a quick trigger finger on a squirt bottle full of coolant. :-)
    G0X0.Y0.
    G43Z3.H1S2960M3T2
    G99G83Z-400.R3.Q8.F450.
    G80
    G0Z25.
    G53Z0.Y0.
    M30
  1. Peck Drilling v.26
    By robobass in forum BobCad-Cam
    Last Post: 11-19-2015, 08:58 AM
  2. Combining peck drilling cycle with deep hole peck
    By adams4182 in forum G-Code Programing
    Last Post: 07-28-2013, 09:07 PM
  3. peck drilling?
    By Tristar500 in forum BobCad-Cam
    Last Post: 01-20-2010, 08:25 PM
  4. Peck drilling on a 16/18i?
    By TheMoose in forum Fanuc
    Last Post: 09-09-2008, 09:34 PM
  5. v22 peck drilling
    By 68sixspeed in forum BobCad-Cam
    Last Post: 04-03-2008, 10:17 PM
