585,925 active members*
3,538 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > G28/G30 and move to zero do not work.
Results 1 to 10 of 10
    Nov 2015
    260
    Today I noticed that when I click on G28 / G30 or Go to Zero in the TNG v2 software, nothing happens.
    Mar 2017
    1310
    Re: G28/G30 and move to zero do not work.
    Those commands work perfectly. Did you altered them with scripts?
    Nov 2015
    260
    I have not changed the scripts.
    I have to install the latest version anyway.
    Then think it will work again, I hope.
    Can I export the settings and import them in the latest version? Or does that also affect the scripts?
    I haven't done that before.
    Mar 2017
    1310
    You can export/inport settings between TNGv2 versions.
    You can not import setting from old TNG. Well, you can but not all settings are imported correctly and there are many new ones.
    Scripts are just files in "Scripts" folder. Scripts from old TNG do not work with TNGv2.
    15362
    Quote Originally Posted by tantemay View Post
    How are you using them post your code you may not have it in the correct format
    Mactec54
    Nov 2015
    260
    I installed the latest version today, now it works.
    Nov 2015
    260
    Is it possible to have the axes run in a certain order with a G28 or G30 command? Because if everyone drives at the same time, a collision with my vise can occur. I always have to move the Z axis all the way up and only then can I execute the G28 command.
    Feb 2011
    138
    I think that in manual of G-code page17 explains using G28 & G 30 code. Probabbly you can edit in "options-scripts" behavior of both codes.
    If I am wrong please correct me.
    rg
    Mar 2017
    1310
    Google g91 g28 z0. It might be what you want.
    Nov 2015
    260
    oh I'm stupid. I could have thought.
    Thanks for getting started
  1. Replies: 2
    Last Post: 04-04-2019, 10:15 PM
  2. Move work offset (G54) with G10 (18i-T)
    By myhäje in forum Mori Seiki lathes
    Last Post: 01-22-2016, 11:04 AM
  3. move operation windows out of the work area
    By Kochy in forum Uncategorised CAM Discussion
    Last Post: 07-15-2011, 07:42 AM
  4. How to move work rest, IG 400-IV, matrix.
    By -PC- in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-29-2010, 07:22 AM
  5. Crazy move, almost work.
    By slp_prlzys in forum CNC Machine Related Electronics
    Last Post: 04-12-2005, 07:47 AM
