584,802 active members*
4,917 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Intermac 33 CNC issue with material removal
    Jan 2020
    I am new to the CNC world and have a new job where I am taking on both the software side of icam and the hardware side of being the CNC operator. I have no prior experience running a CNC machine, so what I am dealing with is frustrating to say the least and I need help from someone who is familiar with material removal offsets.
    The issue is....that if we upload the cnc program file with a drawing that is the actual size of what the counter top is supposed to be, the cutting tool will cut into the material 1/8 inch in from it's actual size so the finished product ends up 1/8 " smaller than what it should be. We have 1/8th inch stops in place along the edges.
    If we offset the drawing from the actual size before programming in icam and go with a 1/8" offset to make the drawing larger than what it is supposed to be, it normally cuts okay... and takes 1/8th inch off the extra material and we end up with a counter top that is actual size. However sometimes it ends up cutting into the material by like an inch on certain angles.
    Has anyone ever encountered a setup like this before when cutting granite or is this even normal for running a CNC program/machine to cut a piece of material to actual size of a drawing that we send to icam when programming a sequence?
    Any thoughts on this would be greatly appreciated and should a Master 33 Inter-mac CNC machine normally be able to cut to actual size without offsetting a drawing to make it larger... just so it cuts to actual size in real life?
    Aug 2009
    1566
    Re: Intermac 33 CNC issue with material removal
    Check ... Tool Offset settings in CNC try adding 1/4" (.250) to the Diameter Offset for what ever tool you're using. If your're using G41/G42 in the program.
    Dec 2013
    5717
    Quote Originally Posted by machinehop5 View Post
    Or make sure the tool diameter is input correctly in the Icam program.
    Jim Dawson
    Sandy, Oregon, USA
